87 front into a 93 front??
Old Feb 3, 2008 | 11:43 AM
93rustedyota's Avatar
Exclamation 87 front into a 93 front??
will a ifs front end from a 87 toyota pickup fit in my 93 toyota pickup as most of u already know i have very bad rust from guy who had it before me working at a marina but thats ok cause i got it for free and found a guy parting a 87
Old Feb 3, 2008 | 12:16 PM
dlbrunner's Avatar
Yeah, the diff housing is the same. Some later model IFS front diffs have a vacuum operated axle engager thingy, if it was equiped with ADD. If you have no manual hubs, then you have ADD.
Replacing the front axle with a non ADD unit would actually be wise. my buddies dad had his vacuum operated thingy go out on the trail = no 4wd = bummer.
I have an 89 fron diff in the yard, and when it comes time to regear and locker, I will swap out the entire unit.
Oh yeah, make sure the ratios are the same if you are swapping an entire unit in. There are at least 3 different R&P ratios from the factory on the early IFS trucks.
88sasturbotoy
Jan 30, 2026 01:57 PM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
