Help needed on 94 Runner engine removal
Old Jan 31, 2008 | 04:54 PM
ahickman's Avatar
I have pulled everything off a 94 Runner (V6 3VZRE) in preparation for removing the engine but have come to a grinding halt when trying to separate the tranny from the block. Unlike the 22RE, the firewall does not allow easy access to the top most bolts which hold the block to the tranny. Should I be pulling the tranny (automatic) out with the block, or is there a secret to getting to the top most bolts? Any help is greatly apprecaited.
Old Jan 31, 2008 | 05:09 PM
Cyberman's Avatar
When I pulled mine (manual), I originally was going to pull the whole thing. I realised that I didn't have the height I needed with the engine crane. But while pulling it up, it gave me access to the top bolts. I pulled the top bolts, loosened to bottom ones, put it back down, and pulled the bottom bolts.
Old Jan 31, 2008 | 05:10 PM
Elvota's Avatar
Generally those top bolts can be reached with a long series of extensions... some weeble style intermixed will also help. I am almost back to the transfer case output flange getting the right angle on mine.
They are hard to get to.... that's for sure.
Old Jan 31, 2008 | 05:17 PM
Cyberman's Avatar
Ya, my way required to pull the driveshafts...
Old Jan 31, 2008 | 05:24 PM
RobD's Avatar
Support the transmission tailshaft and remove the crossmember, allowing you to tilt the transmission down so you can access the top bolts. I pulled the tranny and transfer case with mine. Trust me, you don't want to do it that way...seriously.
Old Jan 31, 2008 | 05:32 PM
Cyberman's Avatar
Ya, that way will work
Old Jan 31, 2008 | 05:37 PM
SoCalWheeler71's Avatar
https://www.yotatech.com/forums/f116.../#post50574383
Old Jan 31, 2008 | 05:42 PM
ahickman's Avatar
When you tilted the tranny, were you accessing the top bolts from the wheel well or from underneath the block/tranny?
Old Jan 31, 2008 | 06:06 PM
mt_goat's Avatar
On my removal I moved the engine and tranny forward in the engine bay about 4 inches and got to those top bolts with a breaker bar from the top, (inside the engine bay).
Old Feb 1, 2008 | 10:47 AM
89pickupsr5's Avatar
i got the top bolts with a bunch of extensions from inside th cab where the shifters were(manual) with the tranny tilted down a little
Old Feb 1, 2008 | 11:51 AM
nate V's Avatar
x2 thats how i did mine too. I have also removed the engine with the tranns together that was quite a bit easier if you ask me. Space permitting.
Old Feb 1, 2008 | 12:22 PM
thook's Avatar
Did someone say weeble....?
.....or is it wobble?
Old Feb 1, 2008 | 12:36 PM
Elvota's Avatar
I saw that goofy sucka the other day and he fell right down.
Old Feb 1, 2008 | 12:42 PM
runethechamp's Avatar
Got to all my bolts with just a couple of extensions from under the car. You just need to look for space in the right places, and when you find it, it's not that bad actually.
Old Feb 1, 2008 | 02:52 PM
thook's Avatar
Say it isn't so!....
arlindsay1992
Jan 23, 2024 01:34 PM
voiddweller
19
May 2, 2016 09:10 PM
yamaha73
Jun 18, 2015 06:19 PM
2wdtundra
Jun 18, 2015 05:19 AM
JaredL
Jun 16, 2015 04:47 PM
