Cigarette Lighter Woes
Old Feb 3, 2008 | 05:52 PM
Camus's Avatar
So on my 'new' '93 P/U, my cigarette lighter plug did that thing they do where the little brown cord secondary fuse thing burns out. I figured this since it went out while I was running an air compressor for awhile and the fuse was fine, with a voltmeter giving me a reading for the plug that goes in the back.
Sooo.... I took a little strand of copper wire and replaced the old brown deal. Now, instead of not working, whenever I plug something into the socket, it will blow the fuse! Hoooray!
Seriously though, what the heck am I supposed to do? I was under the impression that replacing the wire was the way to go, but now it just blows the fuse.
Old Feb 3, 2008 | 06:03 PM
just a 22re's Avatar
get a new one from the junk yard and install it cause i dont know what your talking about
Old Feb 3, 2008 | 06:06 PM
toytech76's Avatar
its probably shorting out on the body of the lighter. Buy a new one and save yourself more trouble
Old Feb 3, 2008 | 06:17 PM
Camus's Avatar
Alright, I'll just pick up a new one and see what happens.
Old Feb 3, 2008 | 07:21 PM
312necro213's Avatar
uhh
You insulated the wire properly right? And also if you have any soldering experience, cut it back as far as possible and solder the wires together to get a good connection to make sure its not blowing the fuse from drawing spurts of power. Also, try to use the same gauge wire that was on there before. Other then that I don't know what to tell you. But make sure its insulated.
potatopants
Sep 15, 2015 06:26 AM
Mrhoadley
Aug 4, 2015 06:08 PM
TDonkey
Jul 26, 2015 10:14 AM
bigblue82
10
Jul 6, 2015 08:27 AM
CUBERA
Nov 21, 2003 03:19 AM
