Noise Question - Detailed Description
Old Feb 6, 2008 | 05:26 AM
baldman's Avatar
Guys,
I recently have a new noise in my '86 4runner (5spd 4WD, 22RE, 150K, stock). She's got 150K on her and runs great (I drive around 100 miles a day). Here is the new noise:
What it sounds like:
Honestly it sounds like a exhaust thwacking/loud ticking (although I'm almost positive that is not the problem) Basically its the normal tick of a 22RE but just amplified (not that it is the engine...just that's what it sounds like)
When it occurs:
In gear, with the clutch out, and the gas pedal depressed. The more gas given, the faster the light thwacking.
It does NOT occur when:
I am stopped in neutral, revving the engine or otherwise.
I am moving in neutral at any speed.
I am moving in neutral at any speed and I revv the engine.
It sounds like it is coming from right under my feet, or possibly under my seat. I thought that it was the exhaust pipe, a connection or clamp, etc. But the more I thought about it (ie not occurring when revving the engine) the less of a chance I gave this idea. I am thinking maybe a mount (engine or tranny) is loose and causing something to hit because it is shifting under load....any ideas?
BALDMAN
Old Feb 6, 2008 | 08:19 AM
MMA_Alex's Avatar
I had an exhaust leak that was audible in the cab only when in gear. The manifold cracked on the back side. Try having someone rev it while you've got your head in there, and you can try to pinpoint it. Mine was audible when you were near it in neutral, just not really audible in the cab in neutral
Old Feb 6, 2008 | 08:22 AM
04 Rocko Taco's Avatar
check your drive shafts... u joints clicking? CV's?
and looooong shot, but there is an old prank where you put a zip tie around the driveshaft so that when it spins the zip tie clicks against the body....
just to check...
Old Feb 9, 2008 | 06:44 PM
84sr5yoty's Avatar
Is it engine ping? Check your timing. Make sure your RPM's are below 900 at idle and that they drop when you short the TE1 connection.
Old Feb 9, 2008 | 06:53 PM
JAvendan's Avatar
hello,
i had a thwacking sound behind my instrument console... it was the speedo cable.
the faster i would go the worst it got.
but, because you are moving, your speedo would still display the current speed but you say the noise isn't there when moving and in neutral...
so, i dunnom
good luck.
joel
Old Feb 11, 2008 | 07:42 AM
RedRider's Avatar
Does it really just happen when the motor is stressed in gear? (like going up hill or accelerating?) Sounds like you may need a valve adjustment... dunno
coleypull15
Nov 3, 2015 07:41 AM
terminator
Jul 27, 2015 07:13 PM
itzmywife's
Jul 25, 2015 04:55 PM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
