What is that sound?
Old Jan 30, 2008 | 07:00 PM
toy4run's Avatar
What is that sound?
1987 4runner stock. Passenger side front loud rubbing sound and vibration only when hubs are locked in. Any ideas. Need to be repacked, replaced?
Not a mechanic, dumb as a rock!
Old Jan 30, 2008 | 07:20 PM
Jay351's Avatar
Do you have manual hubs or the Automatic hubs?
You might want to pull them off and rebuild them.
Old Jan 30, 2008 | 07:28 PM
sleaz22xx's Avatar
as you stated "only when hubs are locked" im assuming that these are manual hubs, i would check fluid level in front diff, check the u joints for exccesive wear(then regrease),and then check for wear in the CV. These are in no order of what might be the problem, just starting with the easy fixes first. Good luck
Old Jan 30, 2008 | 08:00 PM
Jay351's Avatar
crap, I totally missed that. Sorry, long day
I would pull the hub faces and take a peak. If its been awhile I would pull them and rebuild them. Then take a good look at the cv-joints for possible tears in the boots or excessive wear. Like mentioned, check the diff fluid. If its been long I would change it and put some nice fresh lube in.
Old Jan 31, 2008 | 12:19 AM
toy4run's Avatar
Thank you for the quick response!
I guess I'll start asking buddies to help me do this. I'm assuming that you can buy rebuild kits for the hubs fairly easy?
Old Jan 31, 2008 | 02:29 PM
mudbanger's Avatar
sounds like the inner wheel bearing is getting to much pressure when its locked in. replace them
Davebarbier
Nov 3, 2015 03:28 PM
Kamaloha
Oct 16, 2015 05:13 PM
Chicken12
Oct 14, 2015 03:54 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Sep 28, 2015 11:21 PM
