wining noise
Old Nov 6, 2007 | 09:35 AM
swaycleveland's Avatar
wining noise
i have a 93 4runner with a whining noise. i just bought this truck and i have a whining noise while under load. any speed. its an auto i put it in N and the whinging goes away. its only under a load any clues?
Old Nov 6, 2007 | 09:54 AM
littlerunner's Avatar
if its coming from the rear i suspect you got a bad rear end gear
Old Nov 6, 2007 | 09:55 AM
SEAIRESCUE's Avatar
Visit your local transmission shop.
Old Nov 6, 2007 | 10:15 AM
gee thats really helpful
Old Nov 6, 2007 | 10:17 AM
gilby4runner's Avatar
Check the fluid in the rear... replace it and see if that helps any. I have to agree with little runner.
fillsrunner4's Avatar
could it be the alternator they can whine aspecialy under load
Old Nov 6, 2007 | 10:19 AM
ok heres part 2 of this i do 65mph its whining throw it in N and the whining goes away
oops i forgot its a auto!
Old Nov 6, 2007 | 10:21 AM
where is the noise coming from... in front or back?
Old Nov 6, 2007 | 10:23 AM
it seems like front but i cant be sure im gonna change all the fuilds this week any suggestions on what i should use
Old Nov 6, 2007 | 10:26 AM
If its up front it could be a few different things. I take it is a 3.0? Alt. could be a possibility but have you changed out the t-belt lately? Could the tensioner be causing the noise?
im still going with Alt
Old Nov 6, 2007 | 10:29 AM
the t belt was at 101 it now has 200k however the whining doesnt change whing your reve the engine
Old Nov 6, 2007 | 10:32 AM
this is why im stupified it doesnt change with the revs of the engine doesnt do it at any speed while coasting in N im stuck trying to locate this
Old Nov 6, 2007 | 10:35 AM
when its under a load the gears in back are pushing against each other.when ya let off in releases that tension.if its not the rear end i'd be surprised
Old Nov 6, 2007 | 10:44 AM
i guess thats the best place to start then! thanks any recommdations change fuild first or go right into changing gears?
Old Nov 6, 2007 | 10:58 AM
surf4runner's Avatar
start with the easy/cheap things first...
did you try getting rid of the passenger? they tend to whine quite a bit...
Old Nov 6, 2007 | 10:59 AM
be sure & confirm thats where 1st.then just for giggles i would change the fluid & put in synthetic lube.if it has just started the noise it will go quite a while before you absolutely have to replace.when it is time you may be able to find a good used 3rd member & just change the unit out.or if you want to change ratio or add a locker this would be the time to do it.i just happed to have 2 3rd members used if they are the right gear
Old Nov 6, 2007 | 01:35 PM
thanks everyone! im gonna start with the fuild change on AT tranfer and axles and go from there thanks so much for the imput
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
