Valves Adjusted Tighter = More Noise?
Old Nov 1, 2007 | 04:36 PM
GoldenBeaR6's Avatar
So today I adjusted my valves to .008 and .012 cold (as per DOA's instructions for my camshaft). I had to tighten every valve, as they were probably around .012 and 0.17 on average before I touched them. I figured it would quiet my engine down quite a bit.
Bolted her back up, fired her up, and the ticking is noticeably louder. They aren't too bad at idle, but with a little throttle they sure clatter their little hearts out.
Anyone else get this?
Old Nov 1, 2007 | 05:17 PM
DilutedImage's Avatar
Did you adjust the valves while the engine was cold? They're supposed to be done with it at "normal operating temperature". There's a simple conversion for doing the valves cold, but I don't remember what it is. Perhaps somebody else knows?
Old Nov 1, 2007 | 05:21 PM
MMA_Alex's Avatar
supposedly you go .001 smaller when cold, but trust me do it when you're warm. there are also recomendations that you go with a little smaller than that anyway. do a search there are a bunch of threads on this topic with a lot of information
Old Nov 1, 2007 | 05:37 PM
I've read most of the threads. The manufacturer of my camshaft states ".008 and .012 cold". I plan on checking them again this weekend, but I'm pretty sure they're a lot closer to spec than they were before.
And they're a lot louder now. What gives?
Old Nov 1, 2007 | 05:48 PM
mr toytech's Avatar
loosen the valve cover nuts w/ the engine running untell the noise goes away. the rockers are hitting the cover!!!
Old Nov 1, 2007 | 06:01 PM
I only torqued them down to 4-5ft/lbs as per specifications. I will try that though.
Old Nov 1, 2007 | 06:05 PM
I'm sure you checked, but I'll mention it anyways ... Make sure your oil isn't low.
Old Nov 1, 2007 | 06:31 PM
Yep, oil was changed this week.
Old Nov 1, 2007 | 06:39 PM
here are some pics
Here are a few pics I snapped. Does anything look out of the ordinary to you?
I think the timing chain guides looked OK.
Old Nov 1, 2007 | 07:26 PM
javadoody's Avatar
grab the top of the driver's side guide and try and wiggle it. if it moves you've got trouble. it generally snaps between the two bolts.
this was mine: http://i235.photobucket.com/albums/e...chaincrack.jpg
Old Nov 1, 2007 | 07:51 PM
SCYOTA's Avatar
Sometimes the rocker arm adjuster screws become worn and cause valve train noise. How many miles are on the engine?
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coleypull15
Nov 3, 2015 07:41 AM
calderp
Jul 27, 2015 09:58 AM
razorman8669
Jul 12, 2015 12:13 PM
Gamble_STi
Jul 7, 2015 07:54 PM
