Can you identify this plug?94 3.0 4x4
Old Nov 2, 2007 | 10:40 AM
jbridered's Avatar
I noticed a 2 prong gray plug hanging on the passenger side just below the transmission. One wire is Blue with red stripe and other is White with blue stripe. Anyone know what this plug is for? Thanks
Old Nov 2, 2007 | 02:30 PM
just a 22re's Avatar
um........... year model motor size trany type sounds like we were declined much needed to know information
Old Nov 4, 2007 | 10:57 AM
jbridered's Avatar
My truck is an automatic. The rest of the info was already stated on the title. In case you cant see it 94 4x4 3.0
Old Nov 4, 2007 | 11:59 AM
anotherjeff's Avatar
Speed sensor? Is your speedometer working?
Old Nov 4, 2007 | 12:53 PM
jbridered's Avatar
Speedometer is working just fine. Cruise control isnt so maybe thats it.
Old Nov 4, 2007 | 12:56 PM
Albert.G's Avatar
its most likely a "what if" wire, from factory, incase you wanted to add something or convert something
Old Nov 4, 2007 | 01:01 PM
SEAIRESCUE's Avatar
There are at least 3 plugs that connect the automatic to the wiring harness. Several go over the top of the transmission with a two wire plug connector usually at the top of the transmission. From where the transmission harness connects with the computer wiring harness at the starter area, chase them out one at a time and you should find the culprit. So get busy. The no OD is a clear symptom of a disconnected wire.
Old Nov 4, 2007 | 03:08 PM
davenjai's Avatar
That's the only thing I would worry about. Don't know if it's that though.
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
Coreyr384
Jul 10, 2015 11:13 AM
