1986 4runner 22r EFI not starting no fuel
Old 11-08-2007, 05:12 AM
klove97220's Avatar
I have a 1986 4runner that wont start.
It is not getting fuel.
I have replaced the fuel pump relay @ the fuse box.
I have replaced the ECM.
I have replaced the fuel filter.
I have ran direct power to the fuel pump and it pumps fuel.
The engine will run if I spray starting fluid in the breater intake but dies as soon as I stop spraying.
Is there anyone that has a idea what I should try next?
Please help!
Old 11-08-2007, 06:37 AM
dcg9381's Avatar
Please help!
Search google for "4crawler fuel pump".
4cralwer has a web page that will show you how to by-pass the AFM switch and trigger the fuel pump.
The short explanation - and the one thing you haven't checked is that the fuel pump turns on ONLY durning cranking. It's triggered by air flow across a flapper in the AFM. No air flow = no fuel pump.
It can also be triggered manually by grounding a connection on the AFM connector, but you'll have to look that up carefully. Essentially you're grounding the relay to activate the fuel pump.
Old 11-08-2007, 11:57 AM
klove97220's Avatar
Thanks, I will give it a try.
Kevin.
camdenbuck
07-07-2015 07:33 AM
rbravo1
06-29-2015 01:34 PM
torgeir
06-25-2015 05:26 AM
shadowbirdie
06-24-2015 03:54 PM
paxanders
06-21-2015 06:29 AM
Quick Reply: 1986 4runner 22r EFI not starting no fuel
