my clutch is slipping
Old Nov 6, 2007 | 06:39 AM
gametom's Avatar
ok so my clutch started to slip yesterday i think. if i am moving and rev above 2500 it continues to semi freely without accelerating. what can i do some one told me to adjust it. i don't know what or how.
Old Nov 6, 2007 | 06:58 AM
eric-the-red's Avatar
No adjustment on hydraulic clutch systems, you'll have to replace the clutch.
Old Nov 6, 2007 | 07:21 AM
gametom's Avatar
then what is a good clutch to use?
Old Nov 6, 2007 | 07:44 AM
amgraham's Avatar
I use Exedy stock replacements with good results. I just pulled mine the other day after about 18K miles and a year and a half (and a good amount of wheeling) and it really didn't have much visible wear.
Old Nov 6, 2007 | 08:33 AM
Jay351's Avatar
Marlin crawler makes a very good clutch Pretty much oem but with higher clamping force
You can also buy the shifter seat and socket at that time aswell.
Old Nov 6, 2007 | 01:14 PM
gametom's Avatar
how much longer will a ceramic clutch last compared to a ome type one
and are the heavy duty one's worth the money
Old Nov 6, 2007 | 01:46 PM
dlbrunner's Avatar
If you wheel the heavy duty might be good. I found after a long day on the trail (6 hours) the stock clutch would start to "Fade" or slip. I am pretty hard on clutchs tho
No experience with the ceramic.
Old Nov 6, 2007 | 01:56 PM
gametom's Avatar
right now the truck only sees light wheeling since it's mostly stock
as soon as i get some money and find me a nice taco this will become a trail rig
i'm thinking the ome one from wabfab right now
is there anything else i should get if i'm replacing the clutch?
Old Nov 6, 2007 | 02:12 PM
jason191918's Avatar
Yes, you may as well do the rear main. If your rear main leaks, this could be why the clutch is slipping in the first place. Either way, for what it's worth I would change rear mains if you're going to have it all apart anyway.
J
Old Nov 7, 2007 | 01:38 PM
dlbrunner's Avatar
I think the clutch kits include the pilot and throwout bearing, but if they do not, get new ones.
I would reccommend pulling the flywheel and getting it surfaced. Every clutch I have replaced I do this.
Also check the rear main seal, If the oil pan is leaking replace it, while the tranny is out it is a lot easier to do this stuff too.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
