Fuel Filter repacement write up for 22re/Rte?
Old Nov 20, 2008 | 02:59 PM
swerks's Avatar
Any one have a write up or helpful tips?? I did do some searching and I know its not a fun job
Old Nov 20, 2008 | 03:49 PM
thook's Avatar
My only helpful tips are to A) remove the front tire, B) don't smoke whilst doing the deed, and C) plan to relocate it.
Other than that, don't do it a auto parts parking lot with cold wind blowing and no sunlight after having driven through mud the very same day. Engh.....
If that's your option, though, have some q-tips handy.
Old Nov 20, 2008 | 03:57 PM
abecedarian's Avatar
/me lolz at thook
Old Nov 20, 2008 | 04:01 PM
the fuel filter is above the starter and in probably the most difficult place to put a wrench or socket anywhere on that truck. if you can pull the starter, you'll gain yourself some extra room. ratcheting wrenches may gain you some advantage on the fuel lines. a 12mm socket and either highly dexterous fingers or universal joints and extensions might actually get the filter out.
toyota apparently either considers the filter a 'lifetime' piece, or that the FI system can cope with some detritus, but we all know that can't be true.
oh, and don't re-use the copper washers that came off the filter.
I had the filter replaced on my 91 by a facility a while back and the cost was 75 dollars for labor... guess they thought they could do it in an hour?
4 hours later, it was done and we were told to not ask them to do it again.
Old Nov 20, 2008 | 04:02 PM
thook's Avatar
/me grins at abe
Old Nov 20, 2008 | 04:04 PM
Originally Posted by thook
/me grins at abe
stop flirting with me, dagnabbit.
thook's Avatar
I've reused the copper washers before with no leaks. Dropped one of the new ones never to be seen again. Guess it's a gamble, though. So, don't reuse them............especially considering you'll have new ones with the new filter. Unless, you drop one......
Old Nov 20, 2008 | 04:05 PM
thook's Avatar
/me pinches abe......and grins again.
Old Nov 20, 2008 | 04:07 PM
thook-
you know that motel 6 will leave the light on for you, right?
thook's Avatar
Come on, Abe.........help me with my truck.
https://www.yotatech.com/forums/f116...ration-159756/
Old Nov 20, 2008 | 04:08 PM
thook's Avatar
Oh....they leave several lights on for me. I frequent them often.....
Old Nov 20, 2008 | 05:53 PM
myyota's Avatar
Changing the fuel filter is not that hard, it only takes about 30 minutes, and you don`t need to remove the starter.
Old Nov 20, 2008 | 05:55 PM
didn't say you need to remove it, just said it makes it easier.
when the local lube shop took 4 hours to do a .5-1 hour job, I laughed.
Old Nov 20, 2008 | 08:42 PM
Matt16's Avatar
Its a lot easier to assess the fuel filter from the little access hatch in the front passengers wheel well than reaching in from above.
Old Nov 20, 2008 | 08:49 PM
good thing the OP has 4wd, or I'd have to ask you where that access point is on a 2wd.
Old Nov 20, 2008 | 09:09 PM
Matt16's Avatar
Do the 2wds not have that access hatch? You could fix that with a sawzall.
Old Nov 20, 2008 | 11:46 PM
no hatch. the body is closer to the frame on a 2wd, due in part (or in whole, actually) to the 2wd torsion bars being on the lower arms as opposed to the upper arms like the 4wd trucks.
Old Nov 21, 2008 | 07:19 AM
chewie1014's Avatar
I've learned something new today...but since he does have a 4WD...
Pull the front tire, remove the access panel and get to it. It'll take about 30 minutes and a couple choice phrases (you can pick your own phrases, but I've got a couple clever ones if you'd like to borrow them) to get it off, but it's quicker than pulling the starter or going in from anywhere else.
For all the things Toyota has done right with their trucks, locating the fuel filter on the block hidden from view isn't one of them!
Oh, and I used a wrench and a 3/8" drive socket with a 3" extension. Tight fit, but I got it in there.
Old Nov 21, 2008 | 12:09 PM
swerks's Avatar
So, has any one relocated this filter since its so hard to get at ??????
Old Nov 21, 2008 | 12:52 PM
chewie1014's Avatar
Thought about it...but relocating it would take more time than replacing it several times. I'm content to just put up with the aggravation for a half hour rather than reroute it completely.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
