No heat after heater core replacement
Old Nov 23, 2008 | 06:18 PM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I just put on a new head gasket 2 weeks ago, and had to change the heater core as it was leaking inside the truck, so today I get the new core in, refill the coolant, let it burp, warms up and I still dont have hot heat. It is luke warm. The water pipes going into the core from the engine are hot, but no hot air, any help would be nice,
Truck ran for 40 minutes and no coolant leaks anywhere.
Old Nov 23, 2008 | 06:50 PM
thook's Avatar
Is the heater valve working......opening/closing as it should?
Old Nov 23, 2008 | 07:40 PM
abecedarian's Avatar
thermostat stuck open?
Old Nov 23, 2008 | 08:43 PM
SpecialScottie's Avatar
x2 The heater valve often gets build up in it and becomes plugged. A little cleaning and some wd 40 should do the trick
Old Nov 23, 2008 | 08:45 PM
Tubbyfatty's Avatar
That is exactly what happened to me and my friend while working on his 92 PUP. Just busted out the can o lube and she opened right up, ha.
Old Nov 23, 2008 | 09:32 PM
DeathCougar's Avatar
I would guess you still have air in there. Drain the coolant about 1/2 way. Then remove the hose from the actual heater valve and do two things:
1. Inspect the valve, make sure its operating correctly.
2. If so, fill the coolant WITH THE HOSE OFF until it comes pouring out the hose. Reattach the hose, fill the system the rest of the way, and you should have no air bubbles left.
If you don't do it like that, and the system doesn't get ALL the air out (its often trapped in the heater core) it will only blow luke warm. If should be SO hot, you can't hold you hand in front of it for very long on full blast.
Old Nov 24, 2008 | 07:28 AM
I suppose the heater valve is the little two inlet black box in between the right water hose when looking from in front of the truck. Can I just disconnect the pipes and take it off or will that be to much trouble? Should I just go get another one? Also, there is a panel inside the heater core housing that you can open, like a door, and see the heater core. Well, I think I forgot to close that little panel back on the core so would that have anything to do with no heat? I could just take the duct under the passenger side dash off and close it back, let me know. Thanks for the help.
Old Nov 24, 2008 | 07:39 AM
Nice verbage on the explanation.
Old Nov 25, 2008 | 05:24 AM
control panel levers werent hooked up.....IT WAS KEYSTONES FAULT
msane99
Jul 17, 2015 10:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
