Trouble Replacing Front Brake Pads!!!
Old Nov 20, 2008 | 01:31 PM
chiggin's Avatar
I am trying to replace the front brake pads on my 1994 Toyota Pickup. My first problem was getting the calipers off due to rust. I was finally able to get them off with a little PB Blaster and banging on the wrench with a hammer. Now, I cannot get the cylinder in either caliper re-compressed. I was able to get the driver side caliper compressed some, but not enough to get it back on. It took A LOT of effort to turn the c-clamp I was using to compress the cylinder as much as I did, and I cannot compress it any further. In fact, I will have to get a new clamp since I broke the one I was using while trying to compress the cylinder. I don''t remember compressing the calipers ever being this hard on any other vehicle. Is there a trick to Toyota calipers that I am unaware of? I really hope that the calipers are not done for. Any help will be greatly appreciated.
Old Nov 20, 2008 | 01:45 PM
just a 22re's Avatar
i taqke it your in the salt belt lol well mine were easy as pie they should just go back in and from the sounds of it you might have a stuck caliper
Old Nov 20, 2008 | 01:48 PM
space-junk's Avatar
the calipers tend to get sticky with rust and dirt and such, so you either need to rebuild them or replace them...
do a search to find info on how to rebuild them...
Old Nov 20, 2008 | 03:09 PM
SR5's Avatar
SR5
x2 i had the same proble when i did mine, if you take i to shucks, give them your old core and they will give you a new about $50 per side
SR5's Avatar
SR5
also not all shucks have them in stock, so you got to call around
Old Nov 20, 2008 | 03:29 PM
scope103's Avatar
While it sure sounds like a stuck caliper, before you trade them in you might disconnect them from the brake line and then try to push the caliper in. I had a different make truck where the flex-line clogged inside; you couldn't push the caliper in because the fluid had nowhere to go.
Old Nov 20, 2008 | 04:11 PM
Marc's Avatar
Make sure the cover is off the master cylinder.
Also, rent or borrow a proper caliper compression tool.
It works way better than a c-clamp. I think cause it presses evenly.
Old Nov 20, 2008 | 04:19 PM
abecedarian's Avatar
If the caliper is fully removed from the vehicle, lines and all, and the pistons will not compress rather easily- should realistically only take a few pounds of pressure to do get the caliper piston moving, your choices are to either rebuild or replace the caliper.
Personally, I'd rather replace the caliper.
New/rebuilt calipers come with warrantees... rebuild kits do not.
Old Nov 20, 2008 | 05:56 PM
ddwyer's Avatar
My $0.02:
I've done this job a few times. Aftermarket (rebuilt) calipers are so cheap that I just replace them. At about $30 apiece, I can't justify spending the time it takes to rebuild them (BTW,I did rebuild them the first time).
Old Nov 21, 2008 | 01:59 PM
chiggin's Avatar
After a little closer examination, I figured out how to get the cylinder to compress. Originally, I was putting the old brake pad against the cylinder and compressing the c-clamp against that to help distribute the pressure a little more evenly. Right before I started taking the caliper off to replace it, I tried eliminating the use of the brake pad and put the end of the c-clamp down into the cylinder. It compressed with ease. I guess the pad was pushing against something that would not let it go anywhere. I really wish I had figured this out before I put so much effort in, but I am glad I got it. Thanks for the input from everyone.
Old Nov 21, 2008 | 06:22 PM
if it gave you resistance with the pad in place... is it going to release from the rotor when you let off the pedal?
...just a thought: it may be 'slow' to compress but you should be able to push the piston in with your fingers. If you need a c-clamp to compress it, I'd still contemplate replacing them.
voiddweller
19
May 2, 2016 09:10 PM
DanStew
Jun 29, 2015 10:46 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
stretch786
Aug 3, 2005 02:17 PM
tpg013
Jun 27, 2002 02:16 PM
