Grease gun points
Old Nov 20, 2008 | 06:47 PM
Nothingbutyoda93's Avatar
Exclamation Grease gun points
I was looking for grease inserts on my ride. any help other then the front wheels i already found.
a guy told me the driveshaft has like one or two on it... sounded weird to me.
he said he never greased his and it ceased up on him??? Questions comments or concerns????
Old Nov 20, 2008 | 07:00 PM
95RunnerSR5's Avatar
the slip yoke on the driveshaft has a grease point..both shafts actually. its by the u-joint
Old Nov 21, 2008 | 03:33 AM
justcuz's Avatar
lubrication points
http://www.4x4wire.com/toyota/mainte...ront_end/lube/
Old Nov 21, 2008 | 05:40 AM
MMA_Alex's Avatar
good link to follow above. theres also a little card that shows em all that came with the truck from the dealer. might still be around somewhere? theres a lot of em on the driveshafts. theres also some front end stuff that should be greased, and the steering stops, if they're making noise
Old Nov 21, 2008 | 05:45 AM
aviator's Avatar
See this post there are all kinds of grease pts. on our trucks. Toyota built them to be serviced lol there are also all the pts. up front ie ball joints that need to be done too. A good plan I find is grease it at every second oil change unless I've been fording water then I do it after I get home from that trip. Of course if you drive off road a lot or on dusty roads then do it at every oil change. Just don't over pack the pts. that can be as bad as not doing it at all.
rubrsidedwn
Jul 7, 2016 07:28 PM
Firefightersink15
Nov 23, 2015 10:32 PM
pickle6415
Oct 19, 2015 08:08 AM
ktm192k
Sep 24, 2015 03:36 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
