Got speedo wobble?? Check this first!
Old Nov 25, 2008 | 07:39 PM
qdude79's Avatar
Had classic speedometer "bouncing/wobble" all around the clock. Did a search to see what the most common culprits would be (cable, speedo gear, cable lube) and decided to start with what I thought was the easiest, the speedo cable. Disconnected both ends, didn't see anything but an old speedo cable, 'til I pull back the protective sheathing that Toyota put where the cable would normally come in contact with something else. Found this:
Must've trapped moisture BIG TIME! Rusted through so bad I couldn't believe the speedo worked at all!
My suggestion: if you have "the wobble," look down the cable while still in place and pull back the foreskin (pun intended). It may give you an easy answer as to where to start.
Old Nov 25, 2008 | 07:49 PM
DupermanDave's Avatar
I've looked in my manual for the speedo cable and couldnt find anything. I need a new manual.
Where do you disconnect the cable from the wheel?
Old Nov 26, 2008 | 12:14 AM
breknraj's Avatar
Daave, your cable is connected at the back of your guage cluster, and at the side of the transfer case.
Old Nov 26, 2008 | 03:04 AM
Vanman's Avatar
My mistake, I thought you were talking about the wobble that comes from the mid-section I get when I wear a speedo.
Old Nov 26, 2008 | 03:51 AM
flashkl's Avatar
Dude...not cool at 7 in the morning
Old Nov 26, 2008 | 04:43 AM
And that is why I need a new manual! Mine says it connects to the wheel somewehre. Thanks.
Old Nov 26, 2008 | 08:16 AM
99SR5's Avatar
good to know!
Old Nov 26, 2008 | 08:18 AM
qdude79's Avatar
Sorry for the late response, but the speedo thing had me barfing this morning!
Seriously, mine is a 2wd, so it goes directly to the tranny, but it just screws on to the housing like a garden hose. The connection behind the gauge cluster popped on, have to squeeze/pinch to get it off the back. For ~$20 at Napa, I'm very glad I just swapped it out. While getting behind the gauge cluster isn't difficult, per se, it's not something I wanna do more than once if I don't have to. Speedo is smooth as silk now, and the cruise control works flawlessly. Again, for the ease and relative inexpensiveness of the swap once you've gotten into the dash, I'd recommend just getting a new one.
Blamalam
Mar 12, 2022 07:34 AM
Dieselmann
Feb 19, 2019 02:57 AM
raptor510
Aug 19, 2015 02:15 PM
yourrealdad
Jul 29, 2015 11:08 AM
lfcarrion3
Jul 18, 2015 04:05 PM
