Insulation ideas for steering column hole in firewall?
Old 11-26-2008, 11:01 AM
qdude79's Avatar
Ok, I've got most, if not all exposed holes in the firewall plugged with appropriate grommets and plugs. The only one left (that I can tell so far) is the one surrounding the steering stem. It looks like the original has worn to a point where I can see a bit of daylight through it. A new one is $35 (not cheap for a simple part), but the biggest drawback is having to pull the column to get it in there. Not worth it, to me.
Any ideas on how I can "plug" that hole while still allowing the steering mechanism to rotate? It would almost have to be something I could wrap around it, as I said, I'm NOT pulling the column over this.
TIA
Old 11-26-2008, 12:00 PM
SolidDigital's Avatar
I have duct tape around mine...
Old 11-26-2008, 12:03 PM
Beaniam's Avatar
Spray the harder drying firesafe expanafoam around it. When it dries, turn the wheel and it will break the column free and still remain mostly sealed.
Old 11-26-2008, 12:05 PM
mt_goat's Avatar
I have black silicone chalk around mine. I may have put a little grease on the shaft first to keep it from sticking...I can't remember now.
jasonty
41
12-23-2018 01:00 PM
terminator
07-27-2015 07:13 PM
voiddweller
07-15-2015 03:56 PM
jon.r
07-11-2015 03:34 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Insulation ideas for steering column hole in firewall?
