Rattling at 2500-3000 RPM
Old Nov 26, 2008 | 12:59 PM
DupermanDave's Avatar
Not when in gear if I rev my engine to 2500 to 3000 RPM, I can hear a rattle in the engine (sounds like the PCV valve if you shake it). It sounds like a spray paint can when you shake it really really fast. Almost like a metal ball bearing inside of a metal can.
What is this? I don't think I'm too worried, just curious. Only happens when in neutral.
Old Nov 26, 2008 | 09:36 PM
Pistonman's Avatar
Valve lash, timing chain, or rod knock.
Old Nov 26, 2008 | 09:42 PM
Bigblock's Avatar
She's wore out.
Bigblock
Old Nov 28, 2008 | 02:37 PM
wouldnt be valve lash as I've adjusted those 3 times since the head job. I'd say timing chain. thanks for the pointers
Old Nov 28, 2008 | 02:55 PM
Bigblock's Avatar
Is the ign timing correct?
Bigblock
Old Nov 28, 2008 | 06:19 PM
Bigblock
I doubt it. It was done by ear when we did the head a month or two ago, so I'm going to take it to a shop to have it done right.
Old Nov 28, 2008 | 06:41 PM
Bigblock's Avatar
Not hard to do.
Bigblock
Old Dec 8, 2008 | 10:52 AM
So it happened again when I was driving, and it seemed louder. Could have been because I was tired and cranky and paranoid, but at 3k RPM, when driving, I got this rattling noise. I'm thinking it's the timing chain, but why would that go so suddenly?
Also, I started up the truck and let it warm up and revved it to 2000-3000 RPM, and couldnt repeat the noise. Maybe i'm just paranoid. But if it's the timing chain, wouldnt it be constant and repeatable?
Old Dec 8, 2008 | 10:54 AM
91Toyota's Avatar
Wouldn't the chain expand a little due to hot temperatures?
Old Dec 8, 2008 | 11:03 AM
I would think so. With the truck cold it didnt make the noise, and even with it totally warmed up and sitting idle and me revving the engine I couldn't replicate the sound. I'll see if it makes it again on the way home.
I'm just curious if this is something I should worry about, like the chain grinding it's way into the timing cover and causing some fluid leaks.
TNRabbit's Avatar
It's hitting the cover before the oil gets up to pressure. Sign of trouble to come if you don't change it out before it wears a hole in the cover....
Old Dec 8, 2008 | 11:48 AM
Oil should have been up to pressure. I was driving the truck for 20 minutes while it was already warmed up. Shouldnt it have pressure by then? I checked my oil levels while I was out there and all looks good. it's full and black (time to change in about 500 miles, actually)
Old Dec 8, 2008 | 12:49 PM
New info I found out while driving home:
It rattles and clicks even when in neutral and coasting at any speed higher than 35mph
It doesnt matter if I rev the engine up In neutral. The truck has to be rolling faster than 35mph
The wheel hubs are locked and I only now took note that they've been locked for a week now.
My muffler has a rattle to it too. If I quickly press and release the gas pedal (you know, like a punk kid showing off his stuff in his pimped out car) then the muffler has a rattle near the end of it's wurrrrring
Rattle = sound like a baby rattle (as in the baby's toy)
Old Dec 8, 2008 | 05:10 PM
any suggestions? could it be my hubs need greased?
ashamsuddin
17
Jul 22, 2024 03:59 AM
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
shredder4286
Oct 1, 2015 01:09 PM
