Weird overheating problem
Old Nov 22, 2008 | 05:36 PM
orbital02's Avatar
My 87 runner seems to keep overheating. I have replaced the entire engine (22re) about 4 months ago. New radiator. New thermostat. I flushed all the coolant. The problem started about 3 weeks ago when all of a sudden, the truck overheated. It was over a gallon low on coolant. I checked the radiator and oil for signs of mixing, but none. After a few times of this happening, the coolant finally started to show up in the oil. However, the oil level didn't go up, it just got a little milky. We just got done replacing the head gasket yesterday, but the bad news is that the gasket looked good. So the question is: why and how did the coolant mix with the oil? If I was wrong about the head gasket, then it will still continue to overheat. Thanks for any support.
Old Nov 22, 2008 | 06:10 PM
rev. chuck's Avatar
take your radiator cap off and see if the water bubble's if it does the heads cracked (since u changed the gasket)
easiest fix is to get some blue devil liquid glass 60 bucks a bottle
Old Nov 22, 2008 | 06:20 PM
ScottyC's Avatar
Timing chain cover.
Old Nov 22, 2008 | 06:39 PM
chewie1014's Avatar
Originally Posted by ScottyC
Timing chain cover.
I'd generally agree. My hesitation is you said you replaced the entire engine just a couple of months ago. Was it new or reman? Or just a newer used one? If new or even reman, it shouldn't wear through that quick. Still you never know.
Old Nov 23, 2008 | 06:36 AM
orbital02's Avatar
I bought a brand new short block and brand new head The only re-used part was the timing chain cover, but i cleaned it up.
Old Nov 23, 2008 | 06:41 AM
orbital02's Avatar
the other thing I didn't mention is that the truck lost about 3 or 4 gallons of coolant before we changed the head gasket, but the coolant wasn't showing up in the oil or on the ground. So i dont know if it was burning it while driving or just some leak only while it was driving??
Old Nov 23, 2008 | 10:25 AM
abecedarian's Avatar
intake manifold gasket maybe?
Old Nov 23, 2008 | 10:31 AM
TOYOTA 1's Avatar
Abe i like your Sig lol..
except, it doesn't matter what you have if you don't know how to use it
Old Nov 23, 2008 | 01:10 PM
chewie1014's Avatar
Possible...or the throttle body gasket. Could be pulling coolant into the cylinders and burning it off slowly. Any white smoke/steam in the exhaust? Run it a bit, shut it down, remove the air intake tube and smell for coolant from the throttle body.
Old Nov 23, 2008 | 01:16 PM
maybe the idle air valve under the throttle body (if it happens to be the coolant warmed one) leaking coolant up into the throttle (esp. under pressure when the engine is warm and off).
either way, intake gasket or IAV, it's downhill into the cylinders from there so the coolant would only have to drip.
Old Nov 23, 2008 | 01:46 PM
orbital02's Avatar
thx guys i will check these out
Old Nov 27, 2008 | 09:15 AM
small town BIG TOYS's Avatar
Doe's your timing chain cover leak oil?
the1998sr5
15
Jul 14, 2020 08:35 PM
Logz808
Jul 26, 2015 07:09 AM
the1998sr5
Jul 16, 2015 06:20 AM
icentropy
Jul 14, 2015 10:23 AM
Avenged
Jul 9, 2015 07:55 AM
