jumpy idle
Old Dec 26, 2006 | 03:42 AM
19RUNNER86's Avatar
jumpy idle
havin a little problem. once my truck is warmed up if i come to a complete stop and hold donw the brake my idle surges. its only when i press the brake at a full stop. it surges from 900rpm to aboot 1700rpm. just jumps up then down. checked all vacuum no leaks any help will be greatly appreciated!!! thanks guys 86 4runner 22re 5 spd
Old Dec 26, 2006 | 07:10 AM
spudrunner's Avatar
hmmm, maybe check your brake booster line for starters.
Old Dec 26, 2006 | 07:21 AM
19RUNNER86's Avatar
did that already...
Old Dec 26, 2006 | 07:58 AM
spudrunner's Avatar
Do a search on idle or idle problems. This one may help,
https://www.yotatech.com/forums/show...highlight=idle
Old Dec 26, 2006 | 06:08 PM
smar06's Avatar
The brake booster unit it self could be leaking. You may not notice the problem when the truck is cold because the idle is alot higher and the fuel mixture is alot fatter. The brake booster is easy to check. warm up the truck then run the truck untill the idle starts surging then remove the vacuum line from the booster unit and plug the line. If the suging stops replace your booster. let us know what happens.
Old Dec 26, 2006 | 06:11 PM
4Crawler's Avatar
See the page below for the full answer:
- http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html
Old Dec 26, 2006 | 06:27 PM
tkm433's Avatar
Had the same problem with my 94 22re and did a search and found out that I had my idle set to high.
It seems from the info that I found on this or another toy site that there is a link between the fuel injection system and the brakes in that when you apply the brakes it send a signal to the computer to tell the fuel injection to slow the flow of fuel so the EPA is happy.
I noticed this idle issue mainly with the AC on at traffic lights and the like. I lowered the idle one turn and I no longer have the issue with the idle.
You could also have a vaccum leak in one of the many hose that the EPA has forced Toyota to install since the 22re is a dirty motor.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
