Ghost truck
Old Jan 2, 2007 | 12:24 PM
Sonofmayhem's Avatar
Ghost truck
well i got a starting issue fixed, however now the truck will try to start with no keys, if both battery terminals are connected, it has a new starter and a new battery its an 89 4runner 22re, 4x4 5spd.
Thanks.
Old Jan 2, 2007 | 12:30 PM
HaveBlue's Avatar
Sounds like a relay to me. I'd check the starter relay.
BTW - Which springs are you in? Idaho, Colorado, or Pagosa?
Old Jan 2, 2007 | 12:43 PM
Thanks, im in colorado springs. Please Excuse my electronic ingorance, but where would i find it? is it the wire OR is it like a fuse?
Old Jan 2, 2007 | 03:32 PM
anyone? id like to get her goin tonight!!!...!!!...!!!...!!!
Old Jan 3, 2007 | 08:25 AM
where can i get a starter relay? i checked websites, but no one had one. (checker, advanced auto parts)
Old Jan 3, 2007 | 08:48 AM
mt_goat's Avatar
Yeah that would probably only be avalible at the dealer. Don't know where is it either but try looking in the fuse box under the hood maybe.
Are you saying that your truck just starts itself with turning the key? Is this a come and go thing or all the time?
Old Jan 3, 2007 | 09:34 AM
but It turns over but wont start, with both battery terminals connected, it just started to happen, after i replaced the starter. Right now i have a terminal disconnected to keep it from trying, but it still wont catch, would that deal with timing? the starter and battery are new, and the alternator has low miles.
the relay itself has no continuity, based off of the FSM
Old Jan 3, 2007 | 07:15 PM
ลลลล i cant find any relay's the dealer wants 200.
Old Jan 3, 2007 | 07:18 PM
HaveBlue's Avatar
Try a "pull it yourself" yard.
The starter relay will look like a small box about the size of a D-cell battery. It should be located under the hood with your EFI, headlight, and other fuses in the box. The fuse box cover should have a diagram with one of the larger items labeled "starter".
EDIT: I might even have a relay on my '83 that should fit.
EDIT #2: Nevermind. I just noticed you have an arrow pointing to your avatar saying "sold" and I read you now have an '89. I think they have a different relay.
Old Jan 3, 2007 | 07:20 PM
drew303's Avatar
goodluck finding a yota at a junkyard? Are the relays the same on other toyota vehicles?
Old Jan 3, 2007 | 07:26 PM
HaveBlue's Avatar
Also check out the Vendor advertising section here. There are a couple Toyota parts guys that sell everything to us at discount. PM one of them and get a price quote.
TACOZILLA is one of them: https://www.yotatech.com/private.php?do=newpm&u=19835
Old Jan 3, 2007 | 07:29 PM
HaveBlue's Avatar
Starter Relay - AutoZone $11.49 p/n 41-5002
Old Jan 3, 2007 | 09:00 PM
I have a toyota only junker down here plus they are popular here.
Old Jan 3, 2007 | 09:01 PM
WHAT! the only site i didnt check, ill pick one up tommorrow, we will have to wheel some time.
The dealer wanted just under 200 for the relay.
Old Jan 3, 2007 | 09:26 PM
DeathCougar's Avatar
that relay and what the dealer is selling are two COMPLETELY different things. Be 100% sure you compare that relay to your old one, so you know its exact before you leave the store.
Old Jan 4, 2007 | 09:44 AM
oh i will i know its not a fuse, like some have told me, its a separate module.
Old Jan 8, 2007 | 04:39 PM
replaced the relay didnt work where do i look? the ignition switch? where and how? thanks
Old Jan 8, 2007 | 06:07 PM
Doc279's Avatar
Look at your wire connections on the starter, it sounds like you may have the battery cable tightened up against the solenoid post on the starter.
That's why it will crank when you touch the battery cable to the battery.
The cable end should touch nothing but the post it mounts to.
Old Jan 8, 2007 | 07:00 PM
Smiling_Jim's Avatar
Doc is right...
If you just put the new starter in, only one of two things could be wrong:
1) The battery hot lead to the starter is touching the relay terminal.
-OR-
2) The starter you bought is bad, and has an internal short in the relay or the starter itself.
I know it's a pain to pull the starter again. But, if you can't find the #1 problem above, you will have to pull it and take it back to the store to have them test it.
Old Jan 8, 2007 | 08:08 PM
ลลลล IT IS haha that is any easy fix let me go mess with it
I dont see why people say the starter or fuel filter is hard, with proper extentions i can have it out in 5minutes
