Ghost truck
Old Jan 8, 2007 | 09:30 PM
Sonofmayhem's Avatar
Now, its not doing anything, i hear the starter relay clicking and that is it.
Old Jan 9, 2007 | 05:49 AM
Doc279's Avatar
Could be a low voltage battery - if it's just clicking.
Did you remove the starter ? Did you find anything wrong with the connections ?
We be trying to help you.
Old Jan 9, 2007 | 04:55 PM
Got it running right i had a wire mixed up along with many other hoses, right now we are searching for a vaccuum leak. anyone have the diagram?
Thanks
Old Jan 9, 2007 | 06:02 PM
ok, so it will only run if the idle is set high. at a normal idle it stalls...whats the dealio
Old Jan 10, 2007 | 04:49 AM
  #25
Doc279's Avatar
If you have a significant vacumn leak it will die at idle. A small vacumn leak will most often cause a high idle, while a larger leak will only allow the engine to run with the throttle advanced.
It could also be timing related - what are you doing to your truck ? this thread all started with a starting problem with the starter ?
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
ACZR
Jun 23, 2015 07:55 PM
gtpman98
Jun 16, 2002 01:16 PM
