22RE coolant drain problem
Old Dec 22, 2006 | 06:25 PM
GT88Yota's Avatar
As the title says I am having a bit of a problem with the coolant drain on the 22RE in my 88 pickup. Well I removed the plug from the block and nothing happened, so I used a mirror to look inside it and it appeared as though some sort of plug was in there which required an Allen wrench to remove it. So I grabbed what I though was the proper sized Allen wrench and tried to remove it, nothing happened. Keep in mind it was pretty gummed up so it was hard to see exactly what I was dealing with. So in a fit of frustration I grabbed a flat headed screwdriver and pushed against the plug. It moved with relative ease and coolant came pouring out.
The problem I have is it does not appear to have returned to its original position. Should I not worry about it or is there some secret to taking it out?
Old Dec 23, 2006 | 06:12 AM
InternetRoadkill's Avatar
I think what you saw was simply old scale that had built up behind the plug you removed. (?)
Old Dec 23, 2006 | 01:45 PM
GT88Yota's Avatar
You're right, thats what it was and I cleared it out. Thanks.
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Colington
Mar 8, 2020 09:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
