ARB/TJM mounting after SAS
Old 12-29-2006, 07:19 PM
NCSU-4runner's Avatar
wondering if those that have the bumpers and have done a SAS could post up pics of how you modified the mounting, especially those who still use it to winch. I've seen several ARB guys with solid axles but never a TJM, does anyone know someone thats done it?
TIA
Old 12-29-2006, 08:24 PM
Elvota's Avatar
I've got a SAS , TJM and a winch.
Had to do some cutting and welded a few different brackets across the cross member. Not to bad. I did cut off more than I needed and would do it slightly differently if I was to do it again... but it works.
I'll try and take some detail pics and post up over the weekend.
Old 12-30-2006, 04:30 AM
thats what i wanted, someone that "would do it different the second time". better to learn from other people's experience. I'd really appreciate the pics.
Old 01-01-2007, 03:36 PM
Elvota's Avatar
Snapped some pics.
Basically, you loose the bolt holes at the frame where the SAS is welded... so the TJM only has mounts to the side. To compensate, I welded a bracket on each side.
The thing I would do differently is the cutting of the TJM bracket. You have to cut off the lower lip that rolls under the frame. I thought I had to cut the entire length, but you really only need to cut two pockets for the SAS hanger to notch into. If I had left the rest un-cut, I think I would have had a cleaner look and more metal to weld/ attach. You'll see what I am talking about when you get ready to hang the TJM.
That said, the route I ended up taking is working very well and I don't have any complaints.
Old 01-02-2007, 06:04 AM
thank you for the pics
:bigclap:
Old 01-02-2007, 06:20 PM
masterwacker's Avatar
I have a SAS with the TJM as well. I will get you some pictures tomorrow. Mine is setup a littel differently. I will explain when I post the pic
Old 01-11-2007, 06:55 PM
When I did my SAS I made sure that the front spring perch was out about 1/4" of an inch. After everything was done I trimmed the bracket setup for the TJM down until the bracket sat right on top of the front spring perch level. After I had the bumper on and everything was where it was supposed to go I welded the bracket to the spring perch and to the frame in several places. Made it a long stronger. Here is a couple of pictures so you see what I am talking about. Hope this helps.
side of bracket that was trimmed and welded
Pull back view of front
Close view of trimmed bracket. I know, I know, I need to strip and repaint!!!
Old 01-11-2007, 06:57 PM
give me a second, I screwed up the picture sizes
Old 01-11-2007, 07:13 PM
why is one gong to full view and the other is not??!!!???!!!!
Old 01-12-2007, 06:18 AM
Elvota's Avatar
Funny.... I was just going to ask you how you got those cool thumbnails to full view to work. My pics always seem to post to big.
Old 01-12-2007, 06:41 AM
thaks for the pictures guys
Old 01-12-2007, 03:36 PM
AH64ID's Avatar
I asked this question about ARB's a while ago, let me see if I can find the thread...
EDIT: Best photos I got in that thread linky
RickyD
10-02-2015 07:53 AM
mountainbrew
Diesel Swaps
09-20-2015 07:12 AM
Flying91
09-10-2015 03:41 PM
pplusent
09-02-2015 11:56 PM
Ryall
09-02-2015 06:48 AM
Quick Reply: ARB/TJM mounting after SAS
