transmission adjustments
Old Dec 27, 2006 | 03:21 AM
Cid_4r's Avatar
hey guys. how can i tell if the linkage on my transmission is properly adjusted?
1995 4Runner, 3.0 V6, 4x4, Automatic Transmission.
Old Dec 27, 2006 | 04:19 AM
mt_goat's Avatar
You want the little red indicator in the shift selector to be in full view when the tranny is in that gear. Easiest way is to loosen the adjustment bolt and put the shift level on the tranny all the way back into park and also put the shift selector in the cab into park. Then just tighten the adjustment bolt back down.
Old Dec 27, 2006 | 05:08 AM
Cid_4r's Avatar
more details.
i guess i should have been more specific. i meant the kickdown linkage.. not the shifter linkage..
thanks again..
Old Dec 27, 2006 | 05:38 AM
mt_goat's Avatar
http://personal.utulsa.edu/~nathan-b...32prelimin.pdf
It's covered in section AT-116.
Old Dec 27, 2006 | 09:03 AM
Cid_4r's Avatar
thank you very much.. mine was about 3mm off..
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
