Not Moving!
Old Dec 31, 2006 | 04:42 PM
DaShry1's Avatar
Unhappy Not Moving!
91 4runner 3.0 a340h auto the runner was sitting for about 12 hours. I put it in drive and no movement put it into reverse and no movement put when I gave it gas the tach went up and still no movement. I engaged 4hi and the same thing happened. I then tried 4lo and the tranny engaged and started moving anjd shifting correctly for 4low. I once again tried to drive in 2hi and still no movement. So I engaged 4lo again and drove for about 1mile checked the fluids again and everything okay so I tried 2hi again and it started working. So I drove for about 15 miles to the hotel and the transmission seamed to be shifting okay. What could be wrong?
Thanks DAS
Old Dec 31, 2006 | 04:49 PM
ChickenLover's Avatar
Your post is very hard to understand. Try rewriting it in a way that is legible.
Old Dec 31, 2006 | 05:37 PM
DaShry1's Avatar
I restated the problem
Old Jan 1, 2007 | 07:30 AM
95RunnerSR5's Avatar
fluid levels ok?
Old Jan 1, 2007 | 07:42 AM
mt_goat's Avatar
I've heard of others on here with that same problem. One guy was on a trip to Moab when it happened, but IIRC hasn't had it happen again since. Do some searching. Good luck.
Old Jan 1, 2007 | 09:38 AM
texsurfer's Avatar
could be a solenoid not working.
Old Jan 1, 2007 | 09:46 AM
Paul H.'s Avatar
Are you in a very cold climate?
90YotaPU
Sep 21, 2015 05:58 PM
TransAmBandit
Sep 20, 2015 06:08 PM
jacked_72
Sep 14, 2015 03:31 PM
old87yota
Sep 9, 2015 12:39 PM
metalhed
Sep 8, 2015 10:54 AM
