Trouble wiring up my map lights
So I picked up a set of factory map lights at the wreckers a while back and i finally got around to wiring them up the yesterday and I ran in to a small problem...
I extended the wires from the map light to reach the centre light but when I tried to figure out which one to hook up to which lead I ran into a problem
The door light switch does not work with the maplights.
Selecting the maps to "door" turns both on (as it should with the door open) but when I close the door they stay on...until I select "door" off.
the individual map light switches switches work as normal.
I can live with this but I would like them to work properly.
Does anybody have the wiring schematic for the interior lights on a 94 4wd pick-up? If so can you send me a copy or linky?
or baring that let me know where the two map wires go.
Thanks Aviator
For info the dome light is wired as follows:
Black = constant 12V
Black w/white stripe = door switch 12v power
map light
red w/ white stripe = ?
red w/ green stripe = ?
Thanks Aviator
map light
The closest I've got is a wiring diagram for a 95 4Runner and it shows the red/white connecting to the black, and the red/green connecting to the black/white. I can email you a copy if you send me an address.
Hate to dig up old thread but,
Aviator, did this work for you?
I'm about to do the same thing
Thanks,
Thanks,
BeMiceElf
10-10-2015 09:40 PM
Johntom240
7
07-13-2015 12:18 AM
