Trouble wiring up my map lights
Old Dec 27, 2006 | 08:57 AM
aviator's Avatar
So I picked up a set of factory map lights at the wreckers a while back and i finally got around to wiring them up the yesterday and I ran in to a small problem...
I extended the wires from the map light to reach the centre light but when I tried to figure out which one to hook up to which lead I ran into a problem
The door light switch does not work with the maplights.
Selecting the maps to "door" turns both on (as it should with the door open) but when I close the door they stay on...until I select "door" off.
the individual map light switches switches work as normal.
I can live with this but I would like them to work properly.
Does anybody have the wiring schematic for the interior lights on a 94 4wd pick-up? If so can you send me a copy or linky?
or baring that let me know where the two map wires go.
Thanks Aviator
For info the dome light is wired as follows:
Black = constant 12V
Black w/white stripe = door switch 12v power
map light
red w/ white stripe = ?
red w/ green stripe = ?
Old Dec 27, 2006 | 01:18 PM
eric-the-red's Avatar
The closest I've got is a wiring diagram for a 95 4Runner and it shows the red/white connecting to the black, and the red/green connecting to the black/white. I can email you a copy if you send me an address.
Old Dec 27, 2006 | 08:39 PM
aviator's Avatar
Thanks Eric PM sent your way... this is what I love about our little forum here...mutual help... Aviator
Old Oct 13, 2007 | 01:22 PM
b.miller123's Avatar
Hate to dig up old thread but,
Aviator, did this work for you?
I'm about to do the same thing
Thanks,
Old Oct 14, 2007 | 09:26 AM
n4ynu1010's Avatar
Hi-Jacker !!!!!!!!! ......................where ?
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Johntom240
7
Jul 13, 2015 12:18 AM
colinmil
Jul 6, 2015 04:03 PM
