90 V6 Idle Oscilation?
Old Dec 25, 2006 | 03:02 PM
Tucson T4R's Avatar
Question 90 V6 Idle Oscilation?
My son's 90 4Runner with a 3.0 V6 has a strange problem that comes and goes. We rebuilt the engine about a year ago and since then this idle problem comes and goes. If you have the AC off and your foot off the brake it idles at 700 RPM steadily. When you press and hold the brake, the engine idle will start oscilating beteen 1200 and 500 RPM almost stalling at times. As soon as you take your foot off the brake the idle smooths back out at 700 again.
It may idle properly for a month and then this problem comes back for a few weeks. We haven't seen any pattern to the timing of the problem.
Sounds like some kind of vacume problem that's tied to the brake system but you got me. I have looked for vacume leaks and loose vacume lines but I haven't found anything yet. Anyone have any ideas?? Thanks.
Old Dec 25, 2006 | 04:45 PM
Tucson T4R's Avatar
Nevermind. I did a search and found that if the idle is set above 1000 RPM then the ECU controls will cause this problem. I set the idle back down to about 700 and we'll keep an eye on it.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
