91 Toyota 22re will not start
Old Dec 22, 2006 | 09:42 AM
Reaper's Avatar
About a week ago, my truck was broken in to and they stole my deck . That?s when the problems started popping up. I lost all instrument lights including ac/heat panel lights. I went to the parts store and put in new fuses. I replaced all fuses with the correct ones now my truck will not start. I can here the starter it just will not fire up. One more thing the engine fuse in the fuse box under the dash as no power going to it.
Old Dec 22, 2006 | 09:44 AM
Elton's Avatar
did you tape up all the wires where the deck used to be ? ...welcome to yotatech and merry x-mas
Old Dec 22, 2006 | 10:04 AM
Reaper's Avatar
Yeah I taped up all the wires, should the check engine light come on when you turn the key to the on position. Are there more than two fuse boxes on a 91 22re?
Old Dec 22, 2006 | 10:09 AM
Elton's Avatar
yes the light should come on when you start it but it go's away and theres a fuse box under the hood by the battery check the fuse that says efi
Old Dec 22, 2006 | 10:19 AM
Reaper's Avatar
The EFI fuse is good, is there a way check if the EFI Main Relay is bad?
Old Dec 22, 2006 | 03:13 PM
PabloA's Avatar
you need two people to check the EFI relay, have someone turn the key, (not on) and put your ear next to the efi relay you should hear a click sound when the key is turned. I had this same damn problem, thinking it was the efi relay or fusing. Ended up being the coil wiring. Check the wiring from the coil to the distributer, even check spark plug wiring. My problem was the plug that connects the two(coil and distributer).
Old Dec 22, 2006 | 05:27 PM
Reaper's Avatar
It's not the coil wiring I get a good spark from the plugs.
Ichneumon
Sep 27, 2015 04:21 PM
DacodaYota
Sep 2, 2015 02:13 PM
puffin04
Jul 10, 2015 09:17 PM
noahstancik
Jul 10, 2015 11:18 AM
Old Red 94
Jun 16, 2015 08:32 PM
