Shock Removal on a Spring Replacement?
Old Dec 29, 2006 | 06:48 AM
excableguy's Avatar
Question Shock Removal on a Spring Replacement?
I ordered a set of OME901's last night for my '91 4runner, and after looking at the tech write ups here, I have a question-- Is it absolutely necessary that I completely remove the rear shocks for this install? If memory serves, I had a helluva time getting the nut on the top stud installed when I replaced my shocks about 3500 miles ago.(There may be an easier way to do that, too!) Thanks for any info, Shane
Old Dec 29, 2006 | 07:02 AM
User 051420's Avatar
Just unbolt the bottom of the shock (it's easy to get to). This just allows the axle to drop a little bit farther, and those springs will go in easier.
Old Dec 29, 2006 | 07:08 AM
SacRunner's Avatar
when i put my 901's in i replaced the shocks at the same time so i pulled the old shocks completely out.
I would think that as long as you unbolt the bottom of the shock mounts that the shocks wouldn't prevent you from swapping the coils.
FYI: when i did mine, I pulled the shocks off, unbolted the hard brake line from the axle housing (except for the last screw by each drum), removed the rubber brake line (mine was only 9", had it been 11" like some have I'd have been fine), and even then i found some strut compressors (that compress from the outside of the spring) really useful, and a free rental from my local Kragen (Schucks/Checkers)
Old Dec 29, 2006 | 07:18 AM
Babypig's Avatar
Unless those shock are longer than stock your gonna want to get some new shock anyways. I didn't at first and the shock basically stretched itself as far as it could go then grenaded themselves with a week. They are not long enough to leave in there. Go with the ome nitrochargers. I think they are N72F's if my memory serves correctly. Your also gonna get a lot more than 1" lift out of the springs. After three months with them I am still at 2.5" of lift.
Old Dec 29, 2006 | 10:02 AM
FredTJ's Avatar
Well, since you need to replace the shocks anyway, it doesn't matter.
You're adding ca 2.5" of suspension lift, you need to use longer shocks else
you'll negate to additional flex that the longer springs could provide.
You'll also have to adjust your bumpstops down for the longer shocks such that you don't bottom them out.
Fred
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
ItsJustD
Jul 7, 2015 07:49 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
