22R/22RE Blocks Interchangable??
Old Dec 27, 2006 | 06:38 PM
SPooNGTP's Avatar
Just got an 86 pickup IFS 5speed 22R that was hit pretty hard but has a good motor and lockers
what i was wondering is would the block on the 86 22R work with the heads and etc on a 87 4Runner with the 22RE since my 4Runner has spun a bearing.. will all the 87 parts bolt over without modification and create a good running motor??
Old Dec 27, 2006 | 06:53 PM
tkm433's Avatar
Click and read this info below: About the bottom of the page they talk about your motor
http://www.babcox.com/editorial/ar/ar400108.htm
Old Dec 28, 2006 | 05:39 AM
maxpower_hd's Avatar
The short answer is yes it should as long as the one in the 86 is a laser block. Look on the bottom of the exhaust side of the block and see if there is a shape embossed in the block. I don't know what its called but it is sort of a circle with two smaller ones atteched to each side. Not quite an oval. If yours has that then it is a laser block and should work fine. If not then it actually came out of a pre 85 truck.
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
moparbay
Oct 6, 2015 09:24 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
icentropy
Sep 10, 2015 05:03 AM
