Idle and over heating problem
Old Dec 21, 2006 | 11:07 AM
El nigno's Avatar
Hi all, replaced the oil, oil filter, air filter and coolant today, when i restarted the engine to check it over, the idle speed starting bouncing up and down between 1500 and 2000 almost like i was revving the engine and at the same time the engine started to warm up and overheat with the gauge going well beyond the half way mark before i kill the engine.cant understand?i have done this before and never had this problem.Thermostat is working as coolant starts to flow in top radiator once correct temp is reached..hmmm i feel doh doh!
Old Dec 21, 2006 | 11:25 AM
kmcc78240's Avatar
YOu might have an air bubbles in the cooloing system,
Old Dec 21, 2006 | 11:44 AM
rdharper's Avatar
As Kevin says, air is a possibility. We assume you did not have an overheating problem before you changed the coolant. If so, it is not likely you have a serious problem. Do a search on coolant air or something like that.
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
