gauge cluster question
Old Jan 2, 2007 | 04:41 PM
drpdmazda's Avatar
i have two sr5 gauge clusters and have a question about them. they both came out of trucks with the 22re motor, one out of a 4runner and the other was a pickup. both were also stick vehicles, i tried to install one in my 89 runner that is non sr5 and couldnt get it to work without moving around some of the wires, is there a way to know which trucks these are interchangeable with? i have two f them and would like to sell them but would also like to be able to tell the potential buyer if it will most likely just plug and play or need some wires moved like mine
any input is greatly appreciated
thanks
jason
Old Jan 2, 2007 | 04:55 PM
amgraham's Avatar
It's plug and play with most 4Runners (mine was). A few 4Runners and some pickups require a tach wire to be run. Also, as you probably know, the 4cyl ones will not work with the V6 and vice versa.
Old Jan 2, 2007 | 10:03 PM
toy4run's Avatar
I have the same problem. Hooked up a SR5 cluster and the only thing that is working right now is the Tach and Speedo, didn't have to run a line to the coil, luck I guess. All other gauges are going up for example: looks like I have a full tank of gas and my motor is about the overheat. All other idiot lights work great though, 4X4, e-brake, seatbelt, etc. If anyone knows how to switch things up to make everything work I would appreciate it too. I have a 87 4runner and the cluster came out of an 1985.
Old Jan 3, 2007 | 01:07 AM
drpdmazda's Avatar
yeah my runner is an 89 and both clusters came out of 89's with the same motors, only difference is mine is auto and they were both stick, but nothing worked on mine.
mussy01
Dec 13, 2016 08:20 PM
gary4runner
Sep 24, 2015 12:53 AM
Esibnitsud
Jul 30, 2015 08:21 PM
88yodabasket
Jul 13, 2015 01:32 PM
