transmission removal
Old Aug 31, 2011 | 11:32 AM
danny eaton's Avatar
cant remove the upper transmission bolt 2nd above slave pistion. been using 1/2 inch 425 ftlb impact 100 psi. any suggestions?
Old Aug 31, 2011 | 12:01 PM
waskillywabbit's Avatar
Bigger ft-lb impact.
:wabbit2:
Old Aug 31, 2011 | 12:11 PM
wyoming9's Avatar
Smile
What Wabbit said or use a 3/4 " breaker bar
Old Aug 31, 2011 | 12:39 PM
not enough room unless i remove half of tranny first, trying to avoid that
Old Aug 31, 2011 | 12:49 PM
guess i need more tools
Old Aug 31, 2011 | 03:04 PM
Resto-noob's Avatar
Try putting on some of the other bolts and then go after the problem one. You probably have the weight of the tranny/transfer case resting all on that one bolt.
Old Aug 31, 2011 | 03:35 PM
i knew that was going to be the problem bolt so i tried that on 3rd, got pissed and then did all the others, though i should do that until i get the problem bolt off, i even tried to cycle it by heating it a little with a torch, im in stockton ca
Old Aug 31, 2011 | 04:30 PM
Resto-noob's Avatar
Yeah, I've gone through tranny removal at least three times. Fun it is not. I'd go easy with the heat, there's some sensitive stuff near there, but you know all that. Have you tried increasing the psi of the compressor. Sometimes the difference between 100 and 125 is enough to do the job. You can even try tightening it a little at 80-100, sometimes that breaks up the crud stopping it from loosening.
Also, my signature about location wasn't directed at you, per se. It appears in all of my posts-it wasn't a direct shot at you. However, if I did live in Stockton, I'd be over to help-I have friends in Lodi who owe me dinner anyway.
Old Aug 31, 2011 | 06:52 PM
skoti89's Avatar
when i had a 3 inch body lift it was cake!!!. I think last time i did a clutch with out the body lift I used a WHOLE BUNCH of extensions, and a swivel rotaing extension(or whatever your call em) along with like a two foot breaker bar.
make sure the socket is on the head of the bolt flush and give it a twist. for some reason I actually think the extensions make it easier. it gives some play while twisting (like bending an antenna or stick I guess) instead of started from a dead stop and trying to break the bolt. For some reason I reall suck at trying to explain things right now.
Old Sep 1, 2011 | 11:44 AM
thanks for the advice all. pretty much same thing as always when working on an older off road vehicle, when i got it there was like an inch of dried caked mud on entire under carriage
chuckross1957
Jun 28, 2019 10:19 PM
Dieselmann
Feb 19, 2019 02:57 AM
Tigbucket
Jul 30, 2015 07:29 PM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
