SR5 arm rests interchangeable/removable?
Old Aug 29, 2011 | 08:17 PM
5speeds+22REs's Avatar
Heeey all, so my driver's door arm rest is cracked and not the greatest as an arm rest, not that these were ever comfortable..
So my picky interior question is, can I get SR5 arm rests to screw right on where the DLX/base ones do, or are they a whole part of the door assembly in 89-95 pickups?
this is for a 95 non-SR5 xcab.
Old Aug 30, 2011 | 07:08 AM
Stuwy123's Avatar
I'm gonna go out on a limb and say they do bolt up the same.
The arm rest is merely bolted to the door panel.
Only two or three screws hold it in place.
Old Aug 30, 2011 | 07:42 AM
fdp101452's Avatar
On my 90 sr5 theres a lot more then two or three screws that hold the arm rest on the door panel. Most of the screws are on the back side of the panel. If your panels have the mounting holes in them, then they should bolt right up, if not you may have to drill a few holes....Rick
Old Aug 30, 2011 | 01:00 PM
Thanks for the responses, looks like if I find door handle/arm rests from 92ish to 95 they should bolt up fine
Stuwy, what year is your rig?
My door is like that one you see in the background here:
and those arm rests do have like a vinyl pad on top right? Just wondering if its even worth changing.
Old Aug 30, 2011 | 04:38 PM
waynesworld's Avatar
find someone in your area thats parting out a 4runner on craigslist and buy the whole door panel...you can probably get it for 20 or 30 buks.
Old Aug 30, 2011 | 04:50 PM
Inferno451's Avatar
Don't know if this interests you at all, but when i added power doors to my runner, i just put on armrests from an 89' accord. Much more durable than the toyota armrests and they look completely factory. I knew that sr5 armrests/door panels are worth their weight in gold (possibly more, actually), so i just went with what was available. They look just like the armrests in the 1980s trucks.
Old Aug 31, 2011 | 10:21 AM
Great ideas, I'll deffinitely look more into the old Accord arm rests, certainly easier than a whole new door panel.. even though that would open up the power option.
Old Aug 31, 2011 | 06:22 PM
Did they look like this?
http://cgi.ebay.com/ebaymotors/Honda...9#ht_500wt_956
Looks like it might work, just not screwing in the top part, it would probably still attach fine. Seems like the holes look more angled horizontal than vertical than the ones in mine do, but like I said still look workable
Old Sep 2, 2011 | 06:57 AM
Stuwy123's Avatar
My truck is a 93.
My parents corolla is a 91.
The arm rests are the exact same.
Two or three bolts/screws and it's off.
It's that simple.
I don't have power anything so it's just an arm rest with a handle.
the1998sr5
15
Jul 14, 2020 08:35 PM
okamikai
Apr 30, 2018 10:19 PM
rusty904
Mar 27, 2017 05:20 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
shisha1999
Jul 13, 2015 11:09 PM
