Engine WHINE.....
Old Sep 8, 2011 | 03:35 PM
woodyth's Avatar
Engine WHINE.....
Couple things.
1987 pickup 22r rn63
1. I got this engine whine, goes along with the rpm's on the engine. got any ideas where to start? I replaced the belt thinking that was it and it got worse!
2. Going to replace valve cover gasket in the morning, Is there anything special I should know?
3. this is a long shot but, My wiper switch handle has broken out and I cannot find a replacement. I am 2+ hours from anywhere and the local parts store says the part is obsolete meaning they don't make it anymore I guess. Do you guys have any ideas of anywhere online I could get one and what it would be called. I don't know if it includes the head light switch too?
Thanks for the help!
Woody
Old Sep 8, 2011 | 03:43 PM
GuitarMike's Avatar
Don't know about #1 or #3, but re. the valve cover gasket....
See if you can get a rubber Felpro set. It comes with the 1/2 moon cam shaft seals, and rubber washers, too. Be sure and change both of those, too!
No gasket sealer if you use the rubber kit....if it's a 'paper-type' gasket, then go ahead and use the RTV. The rubber one goes into the valve cover "thin side first", into the slot....
If the gasket's never been changed before, watch for the washers on the 4 studs to be threaded....grab 'em with visegrips and spin them off! The new ones shouldn't be threaded...don't over-tighten the nuts, just nice and firm. Tighten in a diamond-like pattern.
Label all the vacuum hoses etc. before you take them off (tape on hose and also on where it goes).
The Haynes manual, or FSM, should help, too! You oughtta have the Haynes/Chilton book...
Hope that helps!
Old Sep 8, 2011 | 04:41 PM
hayes203hend's Avatar
when you pulled your belt did you try to move any of the pully's by hand? if not doing so would help you at least limit things down. something may just have a bad bearing, I had 89 p/u with a 22re that did the same thing you are describing and it was a bad idler pully bearing.
Old Sep 9, 2011 | 05:29 PM
woodyth's Avatar
No I didn't but I will just pull the belt and check it out. I don't have an idler pully on this one, just straight alt->waterpump->crank.
Thanks
WOODY
Old Sep 9, 2011 | 05:36 PM
Terrys87's Avatar
Ebay or bone yard for your wiper switch. Usually run about $40.
Old Sep 9, 2011 | 06:22 PM
peow130's Avatar
Thanks
WOODY
Waterpump or Alternator probably have bad bearings and are on their way out.
My guess is the water pump.
Old Sep 10, 2011 | 11:43 AM
woodyth's Avatar
Hope that helps!
Got it changed in eh 45 mins, just tightened them till they stopped. there was only 2 vacuum hoses so that wasn't too bad either. Thanks for the advice!
Woody
Old Sep 10, 2011 | 01:05 PM
DixieThunder's Avatar
Did it fix it? My first thought was pulley on belt of bearings on w-pump/alternator too. Curious to find out what fixes your problem.
Old Sep 12, 2011 | 09:49 PM
woodyth's Avatar
I can't really tell, going to have to replace one piece at a time, alt, water pump, fan clutch. and see, prolly should anyway just to be safe.
Old Sep 12, 2011 | 10:30 PM
xXbrutalXcoreXx's Avatar
It could be the bearing on the tensioner for the fan belt. I had a mysterious squeel for quite some time and all I had to do was take off the belt, take off the pulley, tap out the bearing from the pulley, and repack it with grease. Works like a champ now.
Old Sep 12, 2011 | 10:33 PM
woodyth's Avatar
The problem with that is there is no tensioner, it is set by the alt mount. There is just one single belt on my truck
Old Sep 13, 2011 | 12:20 AM
This may be a stupid question: How in the world do you only have 1 belt on a 22r? Mine has 3 including the AC.
Old Sep 13, 2011 | 02:03 PM
woodyth's Avatar
I got no ac no power steering therefore only one belt~!
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
