Rear Bumper Bracket - Rusty Bolts
Old Sep 12, 2011 | 12:20 PM
Jersey Joe's Avatar
I was going to try and break the nut but I read that they are welded to the frame. Is that true? If so, what are my options? I already PB Blasted the heck out of them for days but no luck. I have access to an angle grinder if that helps.
TIA
Old Sep 12, 2011 | 11:48 PM
yeehaw1's Avatar
I'm pretty sure they are not welded to the frame, actually i'm 99.9% sure they are not. I took thebed, hitch, and brackets off my 88 a few weeks ago with a good freind, and two good breaker bars. Took around 3.5 hours. mostly because the bolts and nuts kept changing size. The bolts break before they come loose sometimes... Keep Applying pressure, something has to give eventually. Sometimes heat can help...but i rarely use it.
Old Sep 13, 2011 | 04:20 AM
waskillywabbit's Avatar
Use an impact, breaker bar and your purse.
:wabbit2:
Old Sep 13, 2011 | 06:47 AM
JBurt's Avatar
The purse is probably your best bet. Maybe you should mace it first.
Old Sep 13, 2011 | 06:52 AM
SCToy's Avatar
3 of mine broke, the last one stripped the threads and spun in place so I cut it off with a sawzall. Just a breaker bar and a good wrench hopefully a properly sized box head wrench you can brace on something to hold the inside while you torque it from the outside of the frame rail.
It's easy, just takes a lot of force to break those suckers free.
Old Sep 13, 2011 | 07:05 AM
westjohns yota's Avatar
yeah mine was the same way but mine was (still is) welded to the frame? just need to cut it and mine honstly looks factory, wouldnt doubt it
Old Sep 13, 2011 | 08:25 AM
skaz85's Avatar
heat them up ! it will help big time
Old Sep 13, 2011 | 11:15 AM
JBurt's Avatar
If you've got a heat gun it works great. I got one for when I'm using shrink wrap and it goes up to about 1000*. Does wonders.
Old Sep 13, 2011 | 02:54 PM
Zelephant's Avatar
I use a propane torch to heat bolts. You can get one for $10-$15, so its cheaper than a heat gun. Hit it with some penetrating oil while it's hot, it'll draw the oil in as it cools.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
jon.r
Jul 11, 2015 03:34 PM
Vargntucson
Jul 4, 2015 12:15 PM
