Removal of Pin in leaf spring?
Old Sep 15, 2011 | 08:35 PM
96vettelt4's Avatar
95 yota P.U. 4x4..adding a leaf for a 2 inch lift from Toytec. Have everything removed and down to the pin which is in the center of the leaf spring. This pin has to be removed in order to add the extra leaf spring. No bolt head, no thread, no nothing..PB it but it wont budge..how does this pin come out..Toytec says to remove the Pin and discard it as they give you a new bolt to use in its place..but how to remove it is the question....thanx....G
Old Sep 15, 2011 | 09:10 PM
myyota's Avatar
You will probably have to grind the head off of the pin and drive it out with a hammer and punch. Then put it back together with the new hardware in the kit.
Old Sep 15, 2011 | 09:30 PM
cman1's Avatar
yep, the nut is on the bottom,at least mine was,a week ob pb blaster got it off.i just took mine out,it rode like a lumber wagon.i had a busted shock and didnt even know it.
Old Sep 16, 2011 | 03:44 AM
angrybob's Avatar
^^^^X2^^^^
The nut should be on the bottom of the leaf pack. Mine was when I added a mini-pack.
88sasturbotoy
Jan 30, 2026 01:57 PM
nvdesertrunner
May 11, 2020 08:18 PM
4x4-runner
Apr 18, 2017 09:08 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
crashburnoveride
Jul 10, 2015 06:39 AM
