6-7 inch rear lift on ext cab pickup need longer driveshaft?
Old Sep 12, 2011 | 08:29 PM
gary96360's Avatar
hey i was wondering if the driveshaft would bind with a 6 inch rear lift? if so would i have to buy shims. could you lower the carrier bearing by making some brackets? thanks.
Old Sep 13, 2011 | 12:23 AM
Alcan_yota's Avatar
I havent seen any problems with a 5 inch lift causing binding.
Old Sep 13, 2011 | 03:27 AM
rattlewagon's Avatar
Make it a 1 piece shaft.
Thats alot of lift. Why so high?
Old Sep 13, 2011 | 04:12 AM
waskillywabbit's Avatar
Your problem will be length, as in too short.
It's simple Pythagorean geometry.
:wabbit2:
Old Sep 13, 2011 | 01:49 PM
gary96360's Avatar
got bj spacers and add a leaf in the rear, 3 inch body. now going to put in a 4 inch procomp stage 2 lift with blocks. i know the truck is too high for you guys but i dont wheel hardcore like you guys
Old Sep 13, 2011 | 04:55 PM
drmix's Avatar
What size of tires are you gonna run on this thing? Sounds like youll be pushing the limits of the IFS
Old Sep 14, 2011 | 06:10 PM
gary96360's Avatar
im going to lower the front end after lifting it so the angles wont be soo steep
Old Oct 4, 2011 | 08:50 PM
gary96360's Avatar
got an issue. installed the 4 inch bracket lift but the front driveshaft doesnt angle low enough to hook up to the front diff. i took out the diff drop spacers and it still wont work.
6th Gear
19
Dec 10, 2019 07:31 AM
Regency
Jul 5, 2015 08:16 PM
Valvoman
Jun 28, 2015 02:45 PM
94more
Jun 19, 2015 01:55 PM
Old Red 94
Jun 16, 2015 08:32 PM
