Tach not showing correct idle speed
Old Sep 18, 2011 | 02:48 PM
gacinaz's Avatar
Angry Tach not showing correct idle speed
1994 4Runner Automatic
When I connect my tach to the IG of DLC1 it reads 250 yet the dash tach is reading 900. Is this an incompatible test tach that all of the manuals warn about or is this an ECM problem. The tach works fine on my 90 Corolla which has the same DLC1 hookup.
The truck idles fine but has no power on hills and absolutely no torque.
New Head Gasket
I have replaced the TPS and adjusted it. (it was bad)
Cleaned the TB and reinstalled with new gasket.
New plugs and wires
Compression 130 to 135, not great but
New ECM temperature sending unit, old one totally corroded inside
Measured resistance on Knock Sensor and cold start injector
replaced vacuum lines
checked O2 sensor
New fuel filter
Checked fuel pressure right on spec
Maf checks good
Anybody got any ideas?
smthwsn357
May 1, 2024 07:28 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
