IFS rebuild
Old Sep 17, 2011 | 12:29 PM
OntTaco's Avatar
IFS rebuild
I am considering replacing all my steering components on my 1992 pickup as i currently need two ball joints and i thought while i was under there i should replace all the original components with oem. Now my problem is that when i contacted autozone they refuse to sell me this idler arm "FA5040" and say that it won't fit my 1992 pickup the only arm that they say will fit is FA1739. Will sdori bushing work in the FA1739? from the research i've done FA5040 is the correct idler arm for my truck...
FA5040
http://www.autozone.com/autozone/par...er=334889_0_0_
FA1739
http://www.autozone.com/autozone/par.../N-ix0tlZ8oxkx
Old Sep 17, 2011 | 05:00 PM
yotarover's Avatar
i'd say 90% of the idiots working at autozone. dont know jack *censored for yt's family zone junk* from their . i think ur right about the 5040 ...
Old Sep 17, 2011 | 05:30 PM
SoCal's Avatar
I would go to Oreilly and buy MOOG brand parts. Much better quality and they all have Grease Zerks.
Old Sep 18, 2011 | 01:59 PM
OntTaco's Avatar
That idler arm FA5040 will definitely work with my pickup? I would like to be able to grease my steering components but was told the sealed toyota parts were still better quality then any of the aftermarket ones, if this is not the case i would gladly save some $ and get the moog grease able parts.
Old Sep 18, 2011 | 02:51 PM
angrybob's Avatar
This is a current thread and should answer all of your questions about the different idler arms and the FA1739. I just went through this exercise...
https://www.yotatech.com/forums/f116...shings-223846/
Its great info about the bushings at the top, but around comment #19 is the idler arm info. To know what idler arms are out there, click on the 4crawler link that has "idlerarm" in it.
FA1739 has the same shaft diameter as the FA5040 and does NOT have the "555" stamped on the arm which then is not he weaker 2WD arm. From everythign I can tell its the same as the FA5040. I had autozone look up FA5040 and they said it was now special order for like $112
Hope this helps.
pickle6415
Oct 19, 2015 08:08 AM
Kylenicoll33
Sep 17, 2015 08:40 AM
icentropy
Sep 10, 2015 05:03 AM
--Oz--
Sep 6, 2015 01:06 AM
TOYROX
Sep 4, 2015 06:02 PM
