Acceptable wheel bearing heat
Old Sep 6, 2011 | 08:57 PM
the_supernerd's Avatar
I just put 4 new wheel bearings in the front of my '88 2wd pickup. They are Koyo brand and I packed them with Mobil 1 synthetic wheel bearing grease. I drove the truck for about 20 minutes around 50 MPH. When I got back, I felt the hubs. They seemed hotter than they used to be. They were not too hot to touch, but still hot.
Do new wheel bearings heat up while they break in? I thought I remeber reading that somewhere, but could not find it using the search. How hot is too hot?
I believe they are adjusted correctly, or at least not too tight. I adjusted them by torquing to 25 ft-lbs, spinning the hub, loosening it, and tightening the nut to just over hand tight. That put the fish-scale preload adjustment to the lower end of the FSM spec. I figured this might be too loose, but the wheels feel tight and I am not hearing them clank when I hit bumps.
Old Sep 7, 2011 | 04:43 AM
waskillywabbit's Avatar
It's fine.
:wabbit2:
Old Sep 7, 2011 | 08:48 AM
sb5walker's Avatar
New bearings do get pretty warm until worn in. Check them after a couple hundred miles, you may find they have loosened up and need to be snugged up a bit. It seems you are careful not to over-tighten, which is a very good thing.
Old Sep 8, 2011 | 09:24 AM
Thats what I was wanting to hear. I will definately check them after a while.
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
PlayAwhile
Jul 20, 2015 11:36 AM
