cylinder pressure issues
Old Sep 13, 2011 | 02:14 PM
DJsYota's Avatar
i am having hardly any pressure to any of my cylinders i have an 88 22re the pressure is at about 70 on all of them and the 3rd cylinder is not even fireing. i checked the timing it was a little off but it is still having same issues im pretty stumped im new to all this so help would be great
Old Sep 13, 2011 | 02:29 PM
Mandy Tuning's Avatar
bent valves
Old Sep 13, 2011 | 02:36 PM
snobdds's Avatar
Bent valves are a possibility, but more often than not your headgasket is blown.
DJsYota's Avatar
this just happen i was driving the other day and i was going about 45 came to a stop and all the sudden sounded a ran like poop...
thanks for the input
Old Sep 15, 2011 | 05:58 PM
DJsYota's Avatar
the valves are leaking and it needs new injectors im not good with the mechanical stuff so i took it to a mechanic he said he has to grind the valves and replace that the timing and new injectors gonna cost me 2000 this sounds reasonable and is it worth it? i feel like once he is done im gonna have practically a rebuilt engine lol
Old Sep 15, 2011 | 06:01 PM
DJsYota's Avatar
**does that sounds reasonable?**
Old Sep 15, 2011 | 07:06 PM
did you our your mechanic remove the head? an engine is running then suddenly valves are leaking and no compresion? sorry but that doesnt convince me. maybe the valve stuck on the guides if the engine was long time resting or your timing chain jump,for $2000 i will do you a new truck!! i should move to USA.
Old Sep 15, 2011 | 07:26 PM
vital22re's Avatar
totally a bro
get another opinion.. 2k is a little much. How are all 4 injectors bad all of a sudden? have a cylinder leak down test done. Is the cam in time? is it set properly with the crank? Do you have any codes?
Old Sep 15, 2011 | 07:46 PM
DJsYota's Avatar
he did the cylinder test thats how he new it was leaking he said only one injector was cloged but since he is in there i want him to do all of them with new ones since they are the originals wile he is in there he is going to do the timing b/c it was off its almost liek he is rebuliding the whole moter which is fine i have talked to some people that collect toyotas and they said to make the investment the guy i bought it from rebuilt the motor but did a really bad job. but he has had it for 8 days he wanted to for sure make sure this was the isses its been having problems for a while though
bigjstang
Jun 2, 2025 03:56 PM
Sleaker
Aug 26, 2020 06:03 AM
raptor510
Feb 17, 2017 07:11 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
