Bottoming out Bilstein 5100?
Old Sep 7, 2011 | 12:50 PM
96vettelt4's Avatar
95 pu 4x4..22.re..just took off Rancho 5000 and put new Bilstein 5100 all the way around and truck front still bottoms out on medium bumps...these shocks were supposed to be top notch but im not sure.. i was told the 5100 have automatic adjusters built inside..there are no external adjustments..what else would allow truck to bottom out....thanx....G
Old Sep 7, 2011 | 12:56 PM
waskillywabbit's Avatar
You got the wrong length shocks or you got too much load for the valving.
:wabbit2:
Old Sep 7, 2011 | 01:40 PM
96vettelt4's Avatar
4 wheel off road gave me the stock shocks with no lift as i have no lift on the truck..i went back and doubled checked they gave me the right ones and part # is right..i ll double check again...thanx....G
Old Sep 7, 2011 | 01:54 PM
xxxtreme22r's Avatar
are you running low profile bump stops?
Old Sep 7, 2011 | 03:29 PM
96vettelt4's Avatar
no..standard bumpstops...
Old Sep 7, 2011 | 03:31 PM
96vettelt4's Avatar
do lower bumpstops cause a vehicle to bottom out more? i thought it was the opposite...
Old Sep 7, 2011 | 03:57 PM
BMcEL's Avatar
Low profile bump stops will allow the suspension to compress further before they touch. So no, they don't make it bottom out more. Your torsion bars may be fatigued...measure from rim to fender in the front and report back, along with your rim size.
Old Sep 7, 2011 | 04:02 PM
Low profile bump stops make the suspension travel more which affects the shocks. So if the shocks are on a little on the longer side on the collapsed length they will bottom out more with low profile stops in there. Key word in the above statement is compress further meaning the overall collapsed length of the shock has to be shorter for it to bottom out the low profile stop before the shock bottoms itself. Bottom out more maybe not. But you will feel a shock bottom out more then you would hitting the bump stops. So it would feel like your bottoming out more.
Old Sep 7, 2011 | 05:48 PM
BMcEL's Avatar
Good point on the shock length. I've never heard of stock length shocks bottoming out (or topping out) from the use of low profile bump stops, but that's not saying much.
I'm interested in the OPs rim to fender measurement up front. I know the torsion bars on my '90 are on their last leg...they won't crank any tighter and they're at stock height (with a bracket lift). Severely fatigued (or improperly adjusted) torsion bars can ride lower than stock making the truck prone to hitting the bump stops on small bumps.
Edit - a quick way to see if you're at stock height is by looking at the lower control arms...they should be parallel to the center section or angled slightly downward (correct me if I'm wrong on that). If the control arms are pointing up, you're sagging.
ZGjethro
Jun 7, 2017 11:04 PM
live4soccer7
May 11, 2016 06:52 PM
dzldust
7
Oct 6, 2015 05:39 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
toyotasaurus
Sep 24, 2015 03:30 PM
