Install Factory AC
Old Sep 7, 2011 | 06:27 PM
Madathlon's Avatar
Post Install Factory AC
OK Friends, I have a 86 PU with out AC. Has anyone ever pulled a Factory AC from another truck and installed in it theirs, if so how hard was it and what was needed?
Old Sep 7, 2011 | 06:52 PM
91muddog's Avatar
I've heard its pretty easy, I know all the wiring is already there!! Im looking to do the same to mine. Sibscribed
Old Sep 7, 2011 | 11:37 PM
wyoming9's Avatar
Smile
Perhaps doing this is not to hard but there sure is a lot of labor involved !!
The hardest being to replace your heater box with the one with the evap coil in . Knowing you need to remove your old one remove the one from the parts vehicle install in your vehicle While it is out you may as well put a new heater core in
Then you need to find a parts vehicle with the AC system still closed so it is not full of all kinds of things . Then pull a vacuum to make sure you have no leaks in the coils before you start. Convert over to 134A
It is much easier to have the whole vehicle right at hand then buying parts here and there and running all around every time you forgot something
Old Sep 8, 2011 | 01:58 AM
91muddog's Avatar
Well, anyone whose done this have a write up and/or list of the parts needed??
Old Sep 8, 2011 | 04:33 AM
shaeff's Avatar
If I remember correctly, Toyota makes an OEM AC retrofit kit.
bigjstang
Jun 2, 2025 03:56 PM
94whiterunner
9
Sep 22, 2015 07:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
skebe22RTE
Jul 31, 2015 02:03 PM
jetspeedz
Jul 13, 2015 09:32 PM
