1990 4runner A/c works but bogs engine down
Old Sep 1, 2011 | 08:54 AM
easterly81's Avatar
I have a 1990 4runner with the 3.slow 4wd and man trans, the a/c blows cold air but i cannot use it cause it make the truck hard to shift because it bogs the engine down a lot.
Any ideas what might be causing this.
Thanks
Old Sep 1, 2011 | 10:57 AM
Jasper 83's Avatar
How much does it bog it down? Some engine bog is normal because it takes alot of energy to spin the compressor
Old Sep 1, 2011 | 02:21 PM
easterly81's Avatar
Enough that i cannot use it, it makes it hard to shift. I was wondering if its the compressor pulley or just the compressor is to hard to spin.
Old Sep 1, 2011 | 03:10 PM
Levinz11's Avatar
https://www.yotatech.com/forums/f116...dle-ac-119981/
Old Sep 1, 2011 | 03:48 PM
easterly81's Avatar
i have the 3.0 which i believe is different. doesn't the vsv control the idle up for the 3.0 could be wrong. the idle does go up a little when i turn the a/c on. how much should the idle increase. Mine goes up about 100-300rpm.
Ok i was lookin at it and the vsv has that large adjustable spring. is that the adjustment for the a/c idle speed?
Old Sep 1, 2011 | 04:22 PM
Levinz11's Avatar
Originally Posted by easterly81
i have the 3.0 which i believe is different. doesn't the vsv control the idle up for the 3.0 could be wrong. the idle does go up a little when i turn the a/c on. how much should the idle increase. Mine goes up about 300-400 rpm.
Your idle rises 3-400 when you turn the AC on?? Mine goes up maybe 100-150.
Only one to find out about that adjustment spring.
Old Sep 1, 2011 | 04:32 PM
easterly81's Avatar
it seems like the vsv is working properly. I haven't had the car for too long does the a/c rob the car of that much power in these trucks
Old Sep 1, 2011 | 06:04 PM
Levinz11's Avatar
The power loss is definitely noticeable. I don't know what you mean by "hard to shift", though.
vasinvictor
Jan 20, 2016 12:39 PM
rwh2toyota
13
Jun 27, 2015 05:39 PM
gog1968
Jun 22, 2015 05:55 AM
deuxdiesel
Jun 20, 2015 02:49 PM
Bajawfo
Jun 16, 2015 07:31 PM
