22RE - Auto- Tune Up Q's
Old Sep 12, 2011 | 11:07 AM
Vato Loco's Avatar
I have to get my '91 ready for winter for the next few months and I was curious as to what things I should do as far as a tune up goes.
- spark plugs
- oil/oil filter
- air filter
- fuel filter
Anything else?
Old Sep 12, 2011 | 11:15 AM
87 'runner boosted's Avatar
how many miles you got on it and how long has it been since you adjusted the valves???
Old Sep 12, 2011 | 03:41 PM
Vato Loco's Avatar
340,000km, I've only owned the truck close to a year, so I'm not sure when the valves have been adjusted.
Old Sep 12, 2011 | 03:54 PM
Adjust the valves!!!!!!!
Old Sep 12, 2011 | 04:01 PM
Vato Loco's Avatar
Is there a write up? Noob question, I know...lol!
Old Sep 12, 2011 | 04:10 PM
Tools needed : 12mm socket to get valve cover bolts off, 12mm wrench, flathead screwdriver and a set of feeler gauges.
Remove the valve cover, rotate engine clockwise (from a looking at the front of truck point of view) until the timing mark on the crank pulley is at the "0" mark on ur front crank seal/oil pump housing and the mark on the cam sprocket is pointed straight up. Check and make sure the valves on #1 cyl are loose and the valves on #4 are tight, that indicates u are on #1 TDC (top dead center). Adjust the intake valves (valves on the left) to .007" on cylinders #1 and #2. Adjust the exhaust valves (valves on the right) to .009" on cylinders #1 and #3. Rotated the engine one full revolution until your timing marks align again
Old Sep 12, 2011 | 04:11 PM
The adjust the intake on #4 and #3 cylinders and the exhaust on #4 and #2 cylinders. Reinstall valve cover and all is done
Old Sep 13, 2011 | 03:00 AM
GuitarMike's Avatar
Here, have some homework, Vato!
Check your plug wires.
Remove distributor cap and check the rotor - typical tune-up part to replace. If the cap has damage/evidence of arcing, cracks...replace that, too.
Grease your zerks. Clean and grease your battery terminals. Check your wiring at the starter if you can, see if it's clean.
Check your PCV valve (remove it, check for rattle. $6 to replace, if it has been a while just do it or you risk your rear main seal....).
Check the vacuum hoses in that vicinity.
Check that your differential breathers are ok. My rear end blew out (previous owner) and it may have been because of this. Use "Search" for that topic.
Check your oil levels (tranny, T case, diffs...).
nonstop
7
Aug 11, 2015 09:26 AM
ChiefTetlow
Aug 10, 2015 04:19 AM
HollieJayyy
Aug 9, 2015 07:59 AM
JefferDean
Jul 31, 2015 10:39 AM
