Air Conditioner Not Cold When Not Moving
Old Sep 9, 2011 | 12:44 PM
elaketiger's Avatar
Unhappy Air Conditioner Not Cold When Not Moving
I have a 94 with a 3vze. The A/C has already been converted to 134a. Vacuumed the system with gauges and input about 24oz of 134a freon. High side went to about 200, low side only to 25. Funny thing is that it cools great going down the highway (41 degrees at vent), but puttering through the woods the vent temperature goes up to 60 degrees. The 41 degree temp while moving tells me the cooling system is working. The evaporator and radiator look okay. Any suggestions as to what is wrong?
Old Sep 9, 2011 | 01:28 PM
TNRabbit's Avatar
How's your fan & shroud? If your fan clutch is going, that could be part of it.
Also, there is a cutoff switch under the pax side dash that tells the compressor to switch off below a certain RPM (adjustable) to avoid damage. What's your idle set at?
Old Sep 9, 2011 | 01:40 PM
BMcEL's Avatar
I could be wrong but I think yours has an electric fan on the condenser. Make sure it's coming on and the condenser isn't clogged.
Old Sep 9, 2011 | 01:46 PM
BMcEL's Avatar
Amplifier...there's a knob on it for adjusting cutoff RPM.
Old Sep 10, 2011 | 05:58 AM
arcteryx's Avatar
MIne did the same thing, adjust the RPMs and it now blows cold when idle.
Old Sep 12, 2011 | 05:37 AM
elaketiger's Avatar
Fan and shroud are in good shape. The fan clutch is also good (can't stop it by hand). Idle is about 750rpm, I think.
Is the rpm adjustment knob on the dash or under it?
Old Sep 12, 2011 | 05:56 AM
waskillywabbit's Avatar
It's up under the dash.
:wabbit2:
Old Sep 12, 2011 | 07:08 AM
andrewflores17's Avatar
i run r22 (stuff that goes in freezer trucks ) so cold ice gets on the vents some days little unnecessary but hey if you can get it and you want your truck to pull double duty as a freezer go for it
Old Sep 12, 2011 | 08:28 AM
BMcEL's Avatar
Amplifier is on top of the 'cooling unit' on page 1 here. Just need to pull the glove box to get to it.
Also check the condenser fan if yours has one.
Old Sep 12, 2011 | 08:52 AM
Outsane's Avatar
Does your idle speed bump up when you turn on the AC?
MO transplant
Apr 23, 2023 11:58 AM
nanhodges2733
May 29, 2020 03:28 PM
coryc85
Sep 9, 2015 06:24 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
jon.r
Jul 11, 2015 03:34 PM
