Another " I got a noise" thread
Old Apr 19, 2008 | 12:57 PM
swerks's Avatar
Exclamation Another " I got a noise" thread
86 turbo RTE engine sounds like a load of marbles bouncing around the valve cover when I let off the throttle. this noise is not noticable from inside the truck and it seems to be running well. rebuilt engine with about 7000 mi on it. Should I be worried ? what causes this noise ? I never noticed the noise before, but had not played with the throttle under the hood till now.
Old Apr 19, 2008 | 01:25 PM
cutboggers's Avatar
Valves??? maybe have they been adjusted since rebuild?
Old Apr 19, 2008 | 01:47 PM
swerks's Avatar
I was thinking that may be it, that or the timing chain but both were done 7000 mi ago.
Old Apr 19, 2008 | 01:54 PM
cutboggers's Avatar
Do you have enough oil pressure?
Old Apr 19, 2008 | 08:52 PM
iam_turner's Avatar
I've heard noise like this before - it ended up that there was bad gas - diesel in the gas can cause pinging like sounds.
How is the timing?
Old Apr 19, 2008 | 09:17 PM
taandctran's Avatar
It could have something to do with it being a turbo.... I know you are supposed to run high octane in the modern turbo engines.... I dont know if this is true for the early turbo motors. It causes the engine to spark knock. I think it is becouse of a bad air/fuel ratio.
Old Apr 19, 2008 | 09:34 PM
Noltz's Avatar
Nah.. that would occur under boost, not decel. Good thought though. I would go with valves or your timing chain tensioner has loosened off. Definitely get it checked though - that kind of noise is cheaper to fix BEFORE whatever's loose flat out breaks.
Old Apr 19, 2008 | 09:48 PM
taandctran's Avatar
Yeah after I think about you are right... It would only happen under boost. but he did say he was playing with the throttle under the hood. That would make the turbo pressurize right???? but it wouldn't make the engine "bog down" like it had a load on it.... I think that is when it would most likely spark knock.... And it proably has a sensor for that anyway. Right?
Old Apr 19, 2008 | 10:15 PM
cutboggers's Avatar
yessum
Old Apr 20, 2008 | 12:27 AM
swerks's Avatar
I run premium fuel
Daenerysdad
Oct 1, 2015 07:33 PM
joeynational
Sep 5, 2015 01:54 PM
86 87 4Runners
Sep 5, 2015 06:02 AM
Ryall
Sep 2, 2015 06:48 AM
86 87 4Runners
Sep 2, 2015 03:54 AM
