22re dead hole?
Old Apr 21, 2008 | 02:25 PM
TOYOTA 1's Avatar
22re dead hole?
ok i have a 91 22re that is missing on #4 after warm up! i pull #4 plug wire when idling and no change it the way it runs. but the thing is when i first fire it up it runs smooth no missing! but after like 5 min of running it starts to miss on #4. i ran a compression test and it went, #1@165, #2@165, #3@165 #4@125? i no that is a lil low but is it low enough that it would cause #4 cylinder to be dead?
any help would be great!
Old Apr 21, 2008 | 02:39 PM
91Toyota's Avatar
Hmm...interesting. I have 62 psi in my #3 cylinder and it runs pretty smooth. I wonder whats up? Bump for an interesting thread!
Old Apr 21, 2008 | 08:13 PM
dcg9381's Avatar
Try two things:
1) Add oil to the cylinder (just a bit) see if it improves compression numbers.
2) Check valve lash on that cylinder. Too tight can cause that.
Old Apr 21, 2008 | 08:24 PM
TOYOTA 1's Avatar
so i went to swap injectors today thinking that would be the culprit. and i decided to check the oil even though it had only been a few days since i checked it last and to my surprise the oil is white. blown head gasket. but there was no smoke coming out of the tail pipe and would a blown hg be causing my miss?
Old Apr 21, 2008 | 08:39 PM
scuba's Avatar
lol
you finally got up to 62??
ive seen you around here quite a few times
Old Apr 21, 2008 | 08:50 PM
91Toyota's Avatar
Yep...I have tried a product with pretty good results. My other cylinders aren't that good (#150 range) so yeah, its getting better. But I might just take it apart and rebuild it
Sorry for the thread jack!
Old Apr 21, 2008 | 09:23 PM
rowdy235's Avatar
blown hg could definitely cause a miss. Just think about how good a campfire burns when you throw a bunch of water in it . It also makes sense that it would only do it warmed up because thats when the t-stat opens.
But in all seriousness, get a leakdown test done. That'll confirm the blown HG.
Good news is on a 22re the HG job is pretty easy, me and my buddy planned to do his one weekend. We drove it saturday night.
Old Apr 21, 2008 | 10:53 PM
91Toyota's Avatar
Yeah, it is easy and you can do it fast...that is if you don't take the head in to get resurfaced
Colington
Mar 8, 2020 09:51 AM
TJWilly
Jul 31, 2015 02:05 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
